Join, Clip, or Intersect Closed Surfaces
Use the Join, Clip or Intersect Closed Surfaces option (geogxnet.dll(Geosoft.GX.Surface.SurfaceBooleanOperations;Run)*), to combine two closed surfaces.
You can access the option from:
The Oasis montaj Geosurface > Utilities > Join, Clip or Intersect Closed Surfaces menu
The Oasis montaj 3D View > Geosurface > Utilities > Join, Clip or Intersect Closed Surfaces menu
The 3D Viewer Geosurface > Utilities > Join, Clip or Intersect Closed Surfaces menu
Join, Clip, or Intersect Closed Surfaces dialog options
Primary geosurface |
Select the geosurface file containing the primary surface. Script Parameters: SURFACEBOOLEANOPERATIONS.PRIMARY_GEOSURFACE_FILE |
Primary surface |
Select the name of the primary surface from the list of surfaces in the primary geosurface file. It must be a closed surface. Script Parameters: SURFACEBOOLEANOPERATIONS.PRIMARY_SURFACE |
Secondary geosurface |
Select the geosurface file containing the secondary surface. This may be the same file as the primary geosurface file. Script Parameters: SURFACEBOOLEANOPERATIONS.SECONDARY_GEOSURFACE_FILE |
Secondary surface |
Select the name of the secondary surface from the list of surfaces in the secondary geosurface file. Script Parameters: SURFACEBOOLEANOPERATIONS.SECONDARY_SURFACE |
Select action |
Select the action to be performed on the two input surfaces:
Script Parameters: SURFACEBOOLEANOPERATIONS.BOOLEAN_OPERATION |
Output geosurface |
Specify the output geosurface file in which the resulting surface will be written. This can be the same file as either input geosurface file, another existing geosurface file, or a new geosurface file. Script Parameters: SURFACEBOOLEANOPERATIONS.OUTPUT_GEOSURFACE_FILE |
Output surface name |
Specify the name of the output surface. If a surface with the same name already exists in the output geosurface file, it will be overwritten. Script Parameters: SURFACEBOOLEANOPERATIONS.OUTPUT_SURFACE |
Colour |
Specify the colour of the output surface. Script Parameters: SURFACEBOOLEANOPERATIONS.SURFACE_COLOR |
Coordinate Systems
