Simplify or Smooth a Surface
Use the Simplify or Smooth a Surface option (geogxnet.dll(Geosoft.GX.Surface.SimplifyOrSmoothSurface;Run)*), to decrease or increase the level of detail in the surface. The resulting surface may be saved to either a new or an existing geosurface file. If a 3D View is open in your workspace, the target geosurface file will be displayed.
You can access the option from:
The Oasis montaj Geosurface > Utilities > Simplify or Smooth a Surface menu
The Oasis montaj 3D View > Geosurface > Utilities > Simplify or Smooth a Surface menu
The 3D Viewer Geosurface > Utilities > Simplify or Smooth a Surface menu
Simplify or Smooth a Surface dialog options
Input geosurface |
Select the existing geosurface file that contains the surface you wish to modify. Script Parameters: SIMPLIFY_SMOOTH_GEOSURFACE.INPUT_GEOSURFACE_FILE |
Input surface |
Select the existing surface you wish to modify from the list of surfaces in the input geosurface file. Script Parameters: SIMPLIFY_SMOOTH_GEOSURFACE.INPUT_SURFACE_NAME |
Output geosurface |
Specify the name of a new or existing geosurface file in which the modified surface will be written. Script Parameters: SIMPLIFY_SMOOTH_GEOSURFACE.OUTPUT_GEOSURFACE_FILE |
Output surface |
Specify a name for the new surface. If a surface by that name already exists in the output geosurface file, it will be overwritten. Script Parameters: SIMPLIFY_SMOOTH_GEOSURFACE.OUTPUT_SURFACE_NAME |
Colour |
Select a colour for the new surface. The default colour is Magenta. Script Parameters: SIMPLIFY_SMOOTH_GEOSURFACE.SURFACE_COLOR |
Operations |
Simplification |
Select this option to simplify your surface, describing it with approximately half as many triangles and therefore producing a more coarse surface. See Application Notes below. Script Parameters: SIMPLIFY_SMOOTH_GEOSURFACE.SIMPLIFY_RADIO_BUTTON |
Smooth/beautify |
Select this option to smooth or beautify your surface, which effectively places an additional vertex in the middle of each side and fits a smooth surface to the vertices. The output surface contains approximately four times as many triangles and vertices and fewer sharp edges. See Application Notes below. Script Parameters: SIMPLIFY_SMOOTH_GEOSURFACE.SMOOTH_BEAUTIFY_RADIO_BUTTON |
- The Simplification function simplifies the surface by doing an ‘edge-collapse’ operation repeatedly; essentially it replaces an edge with a vertex, and in doing so reduces the number of faces in the surface. This function reduces the number of edges (triangle sides) in the surface by half.
- The Smooth/beautify function uses an algorithm called "Loop subdivision" to subdivide each triangle into four smaller triangles. The method is based on a quartic box spline.
- A new output geosurface will have the same projected coordinate system and units as the input geosurface.
- If the output geosurface exists, the resulting surface(s) will be reprojected into the projected coordinate system and units of the output geosurface.
