Print Preview
Use the Project > Print > Print Preview menu option to display the active map, as it would appear when printed. When you choose this command, the main window will be replaced with a print preview window in which one or two pages will be displayed in their printed format.
When previewing a map, the system gives you the option of selecting the part of the map that you want to preview and whether you want to scale the view or fit it in the viewing window (page).
You have the option of viewing either one or two pages at a time; moving back and forth through the document; zooming in and out of pages; and starting a print job.
Print Preview dialog options
Configuration |
Name |
Select a printer configuration available on your computer.
Select Region to Plot |
Viewed Area |
Select the Viewed Area radio button to preview only the area currently displayed on the map. |
Entire Map |
Select the Entire Map radio button to preview the entire area of the map. |
Panels |
All |
Select the All radio button to print all of the panels of the currently selected map. |
Range |
Select the Range radio button to print only a specified range of panels of the currently selected map.
Panel overlap (mm) |
Specify the panel overlap in map units (millimetres). |
Plot Scale |
Fit to Page |
Select the Fit to page radio button to fit your map to the current page size. |
Scale |
Select the Scale radio button to use a specified scale factor to print your map. Specify the Scale Factor (default is 1) to print your map. |
Fit On Roll |
Check to Fit on roll (for plotters). |
Options |
Print to File |
Check the Print to file box to print your map to a file. |
Copies |
Specify the number of copies of your map to print. |
Centre On Page |
Check Centre on page to centre the plot on the page. |
Offset (mm) X Y |
Specify the offset for the X and Y values. |
