Use the Project > Print menu option to specify how you want your print job to appear and to send a job to the printer.
Print dialog options
To Print a Map:
Select (highlight) the map that you would like to print.
On the Project > Print menu, select Print. The Print dialog is displayed.
Use the Name drop-down list to select the print configuration. Note that the configuration sets the Print Mode, Colour Scaling, and Options parameters. Click the buttons, Change Config, Add Config or Set as default to modify, add and set the default configuration.
Specify the region you want to print: current Viewed Area or the Entire Map.
Specify the plot scale. To maintain the map scale, select the Scale Factor option and specify a value, (1 = 100 per cent). If you use this option, the map may require more than one page depending on the media to which you are printing or plotting.
If the plot is being panelled, specify either the All panels option or the Range of panels option to print. If you are printing multiple panels, you can specify an overlap in mm. This helps you to match panels later.
Specify the number of Copies to be printed.
If required, select the Print to File option box and specify a filename.
Select the Centre on Page option box to centre the plot on the page. To centre the plot on a paper roll select the Fit On Roll option box.
To move the map from its origin (lower left corner of page or plot), specify an Offset distance in mm.
Click the Print button to send the map or plot to the currently configured printer or plotter.
