Free-Air Correction
Use the Moving Platform Gravity > Corrections by Steps > Free-Air Correction menu option, (geogxnet.dll(Geosoft.GX.Gravity.FreeAirCorrection;Run)*), to calculate the free-air correction.
Free Air Correction dialog options
Free air equation |
Choose the equation to apply. See the Application Notes below. Script Parameter AGFACOR.FREEAIR [0- Ellipsoid , 1- Telford] |
Height channel |
The elevation of the observation platform. For airborne surveys, this is the height above the sea level. The default will be set to "Height", if a channel by this name exists in the current database. Script Parameter AGFACOR.HEIGHT |
Latitude channel |
The latitude channel name. The default name is "Latitude". Script Parameter AGFACOR.LATITUDE |
Output free-air correction channel |
The free-air correction channel name. The default name is "FaCor". Script Parameter AGFACOR.OUTCH |
The correction formula:
The Ellipsoid correction formula:
