Bar Symbol Plot Legend
Use the Geochem Map > Point Plots > Bar Plot Legend menu option (CHBARLEG GX) to plot a legend for the Bar symbol plots.
Bar Symbol Plot Legend dialog options
Number of channels
Select assay channel to plot from current database. Any value from 1 to 8 may be selected.
Script Parameter: CHROSE.NUMCHAN
Single bar width (mm)
(Bar plots only). The width of a single bar, in mm.
Script Parameter: CHROSE.LEGBARSIZE
Symbol edge colour
Symbol edge colour, 7 colours available "black outline" (default).
Script Parameter: CHROSE.COLOR
Text height (mm)
The height of the channel text labels, in mm. The labels are plotted around the outside edge of the plot.
Script Parameter: CHROSE.TXTSIZE
Bottom left X (mm)
Bottom left Y (mm)
The location of the bottom-left corner of the plot, in base view coordinates. Use the Locate button to interactively select this position.
Script Parameter: CHROSE.X, CHROSE.Y
Next>
Proceed to define channels.
[Finish]
Plot the legend. If channels or colours remain to be defined, the appropriate dialog will appear before you can plot.
Locate
Interactively define the location of the bottom-left coordinates of the legend.
If this GX is run from the CHBAR GX, or immediately following it, the following parameters will already be set.
Specify Channels
Channel X
Select a channel from the drop-down list. All values must be specified.
Script Parameter: CHROSE.CHANX (Where X is a value from 1 to 8)
Next>
Proceed to define scaling.
<Back
Return to the main dialog
Finish
Specify Scaling
(Channel Name) scaling
The scale value is taken from the "symbol scaling" attribute for the given channel. If this value is not defined, the default scaling defined in the CHROSE GX is used.
Next>
Proceed to define colours.
<Back
Finish
Plot the Rose plots. If channels or colours remain to be defined, the appropriate dialog will appear before you can plot.
Specify Fill Colours
(Channel Name) colour
Select a colour from the drop-down list. All values must be specified.
Script Parameter: CHROSE.COLX (Where X is a value from 1 to 8)
<Back
Finish
This GX is designed to be run from the CHBAR GX, but it may be run on its own.
