Pie Symbol Plot
The Rose (Sector) Plot, Pie Plot and Bar Plot options are used to plot symbols which can represent 1-8 different channel values at each point.
The Pie Plot (CHPIE GX) creates Pie plot symbols where the angle of each pie section represents the relative sizes of the different channel values.
The Rose (Sector) Plot (CHROSE GX) creates Rose (or Sector) plots, which are similar to Pie plots, but each section has an equal angle, and the radius of individual segments scales with the data value.
The Bar Plot (CHBAR GX) plots a bar graph where the height of each bar scales linearly with the data values.
The three plots make use of virtually the same parameters, including colours and scaling factors, so they may be used one after another, with minimal need for re-definition of values.
Rose or Sector Plot / Pie Symbol Plot / Bar Symbol Plot
Specify Channels
Channel X |
Select a channel from the drop-down list. All values must be specified. Script Parameter: CHROSE.CHANX (Where X is a value from 1 to 8) |
Next> |
Proceed to define colours. |
<Back |
Return to the main dialog |
[Finish] |
Plot the symbols. If channels or colours remain to be defined, the appropriate dialog will appear before you can plot. |
Specify Scaling
(Channel Name) scaling |
The scale value is taken from the "symbol scaling" attribute for the given channel. If this value is not defined, the default scaling from the first dialog screen is used. |
Next> |
<Back |
[Finish] |
Specify Fill Colours
(Channel Name) colour |
Select a colour from the drop-down list. All values must be specified. Script Parameter: CHROSE.COLX (Where X is a value from 1 to 8) |
<Back |
[Finish] |
