Create Subset Database
Use the Create Subset Database option (CHSUBSET GX) to create a new SUBSET database from a Master database. The subset database will only include data that is not dummy in the Mask channel.
The option is available with the following menus:
Database Tools > Geostatistics Toolkit
Geochem Analysis in the Geochemistry extension
New subset database |
The new subset database you wish to create Script Parameter: CHSUBSET:DATABASE |
Mask channel |
The channel you wish to use as the mask channel. The default mask channel is set from the CHPREFERENCES GX (Geochem Import/Preferences...). Script Parameter: CHSUBSET:CHANNEL |
The GX is used to generate a subset database based on information contained within the mask channel (ChemMask).
