Interpolate
Use the Database Tools > Channel Tools > Interpolate menu option (geogxnet.dll(Geosoft.GX.Database.InterpolateChannel;Run)*) to replace dummies in a channel, while honouring a minimum gap.
The option is also available with the Geophysics Levelling extension under the Tie Line Levelling > Interpolate menu.
Interpolate dialog options
Both Minimum curvature and Akima interpolation methods define a second-order cubic spline to interpolate dummy values. Minimum curvature produces the smoothest possible interpolation, but may create undesirable over-shoot in some areas, while Akima interpolation tends to be less smooth, but does not suffer from unreasonable over-shoot.
Prediction uses a maximum entropy prediction algorithm to predict the missing values such that they will have noise characteristics similar to the original data; when choosing this option, you can force the two ends of each line to be continuous and maintain periodicity. This is specifically needed for applying FFT filters.
Linear is a standard straight-line technique, and Nearest assigns the value of the nearest non-dummy point.
