Voxel to GOCAD
Use the Voxel > Conversions > Voxel to GOCAD menu option (geogxnet.dll(Geosoft.GX.VoxUtils.ExportVoxToGocad;Run)*) to export a Geosoft Voxel to a GOCAD Voxet.
Voxel to GOCAD Voxet dialog options
Voxel file |
Select the Geosoft Voxel file to export. Script Parameter: EXPORTVOXTOGOCAD.INPUT_VOXEL |
GOCAD Voxet file |
Specify the name of the GOCAD Voxet file to create. Script Parameter: EXPORTVOXTOGOCAD.GOCAD_VOXET_FILE |
GOCAD format limitation: only Geosoft voxels with uniform values can be exported.
