Voxel to XYZ
Use the Voxel > Conversions > Voxel to XYZ menu option (geogxnet.dll(Geosoft.GX.VoxUtils.ExportVoxToXYZ;Run)*), to export a Geosoft Voxel to an XYZ file.
Voxel to XYZ dialog options
Voxel file |
Select the Geosoft Voxel file to be exported to an XYZ file. Script Parameter: EXPORTVOXTOXYZ.INPUT_VOXEL |
XYZ file |
Specify the name of the XYZ file to generate. Script Parameter: EXPORTVOXTOXYZ.XYZ_FILE |
Direction |
Specify how the data will be organized in the file. Can be one of the following: XYZ YXZ XZY YZX ZXY ZYX Script Parameter: EXPORTVOXTOXYZ.DIRECTION |
If not checked, dummy voxel elements will be omitted in the output XYZ file. Script Parameter: EXPORTVOXTOXYZ.OUTPUT_DUMMY_VALUES [0-No, 1 -Yes] |
Direction
The first coordinate in the direction designation indicates the slice plane, the data along the 3rd coordinate changes faster than the 2nd one. For example, in the designation YXZ, an entire slice in the Y plane will be written to the file and in each of these individual sections, consecutive points are ordered along the Z direction, followed by the X direction.
