Manage Template Library
Use the Map Tools > Map Template > Manage Library menu option (geogxnet.dll(Geosoft.GX.MapTemplate.MapTemplate;ManageLibrary)*), to manage any templates that have been added to the template library. The dialog can be reached also from the Template tab in the Map Template Properties dialog.
Manage Library dialog options
Controls |
Template library |
Select the map template to manipulate. |
Preview pane |
This gives a preview of what the template looks like. |
[Delete] |
Click the button to remove a template from the library. |
[Edit] |
Click to edit the name and/or the description of a template in the library. |
Any templates that have been added by the user on a system, reside in the <Geosoft>user/maptemplate folder. This folder can also be used to store supporting files (like logo bitmaps). It is not possible to delete or edit any example templates that are shipped by with Oasis montaj.
