Flight/Tie Intersection Difference
Use the Flight/Tie Intersection Difference option (geogxnet.dll(Geosoft.GX.AirborneQC.IntersectionDifference;Run)*) from the Airborne QC menu to carry out quality control on data values measured at the intersection of flight and tie lines.
Flight/Tie Intersection Difference dialog options
Input database file |
Select the database from which you wish to calculate the |
Data channel |
Select the input data channel from which the intersection differences will be calculated. This could be, for instance, a radar altimeter channel to QC altitudes. Script Parameter: QCINTERSECT.CHAN |
Maximum difference |
Enter a maximum difference value. Locations where the altitude at the intersection point differ by more than this amount will be marked (flagged). Script Parameter: QCINTERSECT.ALLDEV |
Plot results |
Specify if the outcome (flight lines, flagged locations, legend) should be displayed on the current map, on a new map, or not at all:
Script Parameter: QCINTERSECT.MAP [0 – Display on current map (default), 1 – Display on a new map, 2 – Do not plot] |
Map name |
Specify the name of a new or existing map on which to plot the results. The map will open in the foreground. If the map is new, you will be prompted to interactively specify the location of the legend. New information will be added to the map; the legend will indicate the line path colour as well as the colour of the flagged locations and the percentage of the survey that is not within the specifications. When a new map is generated, the map is scaled to the input database extents, and the map projection is set to the projection of the database.
Script Parameter: QCINTERSECT.MAP_FILE |
[More] |
Flag Attributes |
Line Attributes |
This GX assumes that the current database contains data with both normal flight lines and tie lines.
Quality Control Specification and Indicators
The GX first determines the intersection points between flight lines (e.g., L100) and tie lines (e.g., T50) in a database.
Two channels are created and automatically displayed in the active database:
- IntDiff: this channel holds the difference between the intersecting lines. The difference between the data values recorded in the input channel at the intersection points are written to this channel at the rows for which the fiducial is the closest to the actual intersection. The symbols plotted on the map are coloured using this channel and the colour table and method specified in the Flag Attributes tab.
- Flag_Int: this channel contains a value of 1.0 anywhere the difference in the intersection value is outside the specification. All other points, both intersection and non-intersection, are given a value of 0.0.
As the discretely recorded data points are not necessarily exactly at the intersect points, the symbols themselves may not be plotted exactly at the intersections points, but at the point on the flight line closest to the intersection.
