Fill Voxel Dummies
Use the Voxel > Utilities > Fill Voxel Dummies menu option (geogxnet.dll(Geosoft.GX.VoxUtils.FillVoxel;Run)*), to fill the dummies in an existing voxel and write the filled volume to a new voxel.
Fill Voxel Dummies dialog options
        Input voxel  |
        Select the voxel file to be filled. Script Parameter: FILLVOXDUMMIES.INPUTVOXEL  |
        Output filled voxel  |
        Select the name for the filled voxel file. Script Parameter: FILLVOXDUMMIES.OUTPUTVOXEL  |
        Fill type  |
        Select the interpolation type:
