Reproject a Voxel
Use the Voxel > Utilities > Reproject a Voxel menu option (geogxnet.dll(Geosoft.GX.VoxUtils.ReprojectVoxel;Run)*), to reproject a voxel that includes a projected coordinate system.
Reproject a Voxel dialog options
        Input Voxel |
        File name  |
        Select the voxel file to be reprojected. Script Parameter: VOXEL_REPROJECT.INPUT  |
        Coordinate system  |
        The Coordinate system entry is read-only and is automatically populated from the input voxel.  |
        Coordinate system units  |
        The Coordinate system units are read-only and are automatically populated from the input voxel.  |
        Output Voxel |
        File name  |
        Specify the output voxel file name. A new voxel file will be created from the input voxel file, with a modified projected coordinate system. The extension ".geosoft_voxel is added automatically. Script Parameter: VOXEL_REPROJECT.OUTPUT  |
        Coordinate system  |
        The output Coordinate system is read-only and is automatically populated from the output voxel. To change the coordinate system, click the Modify Coordinate System button. The default is "Undefined"; however, once a coordinate system has been set, it will be remembered and populated on subsequent runs. Script Parameters:
        The output Coordinate system units are read-only and are automatically populated from the output voxel. To change the coordinate system units, click the Modify Coordinate System button. The default is "metre"; however, once a coordinate system has been set, it will be remembered and populated on subsequent runs. The  units apply to the horizontal and vertical coordinates of the voxel.  When reprojecting a voxel into a coordinate system that uses different horizontal units, the vertical units are also scaled.
        Script Parameter: VOXEL_REPROJECT.IPJ_UNITS  |
        [Modify Coordinate System]  |
        Click the Modify Coordinate System button to display the Coordinate System dialog.  |
The Reproject a Voxel option creates a new voxel file from the input voxel file, with a modified projected coordinate system. The voxel cell sizes remain unchanged (except for scaling to account for a change in units) and the data is not re-sampled. The origin is altered in order that the output voxel is located at the same geographic location on the earth as the original however, the depth /vertical location of the voxel is not changed. The voxels rotation about the vertical axis is altered to ensure that the orientation with respect to north remains the same.
