Export Pseudo-Sections to Geosoft IPRED Format File
Use the IP & Resistivity > Export > Geosoft IPRED Format option (IPEXPIPRED GX) to export pseudo-sections created from the current database to Geosoft IPRED format files.
Export Pseudo-Sections to Geosoft IPRED Format dialog options
Export
Select which lines to export. The options are the currently displayed line, the selected lines (the default) and all the lines.
Script Parameter: IP.LINES - "A" : All lines, "S" : Selected lines (default), "D" : Displayed line
Title
Title to appear as the first line in the IPRED file
Script Parameter: IP.IPREDTITLE
Channel
Select a channel to export as a pseudo-section. Although some pre-selection is done when creating the channel list (removing X, Y, Z, etc.) it is up to the discretion of the user to select a "reasonable" variable for the pseudo-section.
Script Parameter: IP.CHAN
Filename suffix (type)
The output file names have the format "LINE.SUFFIX". The file name suffix is typically two or three letters. Suggestions include "mf","res","ip0" etc.
Script Parameter: IP.SUFFIX
Filter Type
The Fraser Filter to apply:
1: Regular Pant-leg (default)
2: Pant-leg, single point at top
3: Regular Pyramid
4: Pyramid, single point at top
Script Parameter: IP.FILTER – A value from 1 to 4 from the above list.
Filter Weights
A list in the format w1,w2,w3... of filter weights to apply to each N expansion starting with n=1. Weights must be separated with spaces or commas. Weights for separations greater than the N for the last specified weight are set to 1.0. If left blank, all weights are set to 1.0
Script Parameter: IP.WEIGHTS – A list in the above format.
First station position
Last station position
Positions for the first and last station. If the first station is left blank, the minimum will be used; if the last station is left blank, the maximum will be used. If both are left blank, the entire range is used. By default, these are left blank, and all are used.
Note: The output station values are always integral multiples of the spacing; if the input station positions are not themselves integral multiples, the output positions will lie within the specified range.
Script Parameter: IP.STN1, IP.STN2
Maximum n spacing
The maximum array expansion factor to include in the pseudo-section. The default is 8 (but it may be larger).
Script Parameter: IP.MAXN
The IPEXPIPRED GX is used to export one or more lines from the current database to individual Geosoft IPRED format files. The file names are created from the line numbers and the extension appropriate to the chosen data type (specified by the user). One file is created for each line. Care should be taken as previously created files in the working directory with the same names will be overwritten.
The IPRED format was introduced for the DOS IP system, and was produced by running the IPRED programme on IPDATA files.
