GOCAD to Voxel
Use the Voxel > Conversions > GOCAD to Voxel menu option (geogxnet.dll(Geosoft.GX.VoxUtils.ImportGocadToVox;Run)*), to import GOCAD Voxet files to a Geosoft voxel.
The import only supports GOCAD files in IEEE float format with property data in an external file.
GOCAD to Voxel dialog options
GOCAD Voxet file |
Browse to select the GOCAD Voxet file to import. Script Parameter: IMPORTGOCADTOVOX.GOCAD_VOXET_FILE |
Output voxel |
Specify the name of the Geosoft voxel file to be generated (.geosoft_voxel). Script Parameter: IMPORTGOCADTOVOX.OUTPUT_FILE |
Property to import |
Select a property from the GOCAD Voxet file to import. Script Parameter: IMPORTGOCADTOVOX.PROPERTY |
Coordinate System
Coordinate System |
The Coordinate System dialog allows you to specify the correct coordinate system information (Datum and Projection Method) for the input GOCAD Voxet file. Script Parameters:
If a 3D Viewer is open during the import, the output voxel will be displayed in that 3D view. Otherwise, it will be displayed in a new Voxel Viewer window.
If the output voxel does not display, open the Advanced Settings dialog (Project > Settings > Advanced) and, under the Voxel Settings node, check if the Display Created Voxels option is set to "True".
