Geosurface Properties
Use the Geosurface Properties option (geogxnet.dll(Geosoft.GX.Surface.SurfaceProperties;Run)*) to report and modify information about a geosurface file, including information about the file and its contained surfaces, as well as statistical, geospatial and coordinate system information. The Geosurface Properties dialog presents information in different ways, depending on where it was launched from.
You can access the Geosurface Properties dialog from:
The Oasis montaj 3D View > Geosurface > Geosurface Properties menu
The 3D Viewer and Geosurface Viewer Attributes tab while a Geosurface file is currently selected. Note that two different versions of the dialog will appear depending on whether you have selected the Parent (File level) or the Child (Isosurface level).
Geosurface name |
Displays the file name and path of the selected geosurface file. |
Extents |
Displays the minimum and maximum extents in X, Y and Z for all the surfaces in the geosurface file. |
Coordinate system |
This displays the coordinate system information of the geosurface, if any. Use the Modify button to modify the coordinate system information. |
Coordinate system units |
This displays the length units of the coordinate system. The geosurface origin and point separations are in these units. Use the Modify button to modify the coordinate system projection and units. |
Number of surfaces |
The total number of surfaces contained within the geosurface file. |
Surface Properties
Use the Validate Surface button to perform advanced validation calculations, and to check for any errors in the selected surface.
Surface Validation Properties
- When opened from the application menus, the Geosurface Properties dialog has the ability to select any of the contained surfaces in the selected file.
- When opened from the 3D Viewer or Geosurface Viewer menus, or from the Attributes tab, the properties of the selected surface in the Properties layer tree are available.
- The Surface Validation Properties dialog, opened when you click the [Validate Surface] button, can be useful to determine if the surface mesh is free of errors or if any errors are present. Errors can lead to incorrect rendering, unexpected behavior, or further errors when the surface is used in Voxel Math.
