Geographic Coordinate Systems Transformation
Use the Geographic Coordinate Systems Transformation dialog to specify a datum transformation when adding an ArcGIS LYR, LYRX, or SHP file to the Data view of a map that uses a different datum.
Geographic Coordinate Systems Transformation dialog options
The table lists the data sources currently being added to the Data view that use datums differing from the view's datum.
Convert from |
Select the datum (or GCS in the case of LYR data) for which you want to specify a datum transformation. |
Into |
The datum (or GCS in the case of LYR data) used by the Data view is displayed. |
Local Datum Transform |
Select the datum transformation you want to use from the drop-down list: |
Selected datum transformation parameters: |
