Copy/Convert Grid(s)
Use the Grid and Image > Utilities > Copy/Convert Grid(s) menu option (geogxnet.dll(Geosoft.GX.GridUtils.CopyConvertMultiGrids;Run)*) to copy or convert grids/images from/to other standard grid/image formats.
Copy/Convert Grid(s) dialog options
Input grid(s) |
Select the input grid(s). The default format is the input grid format set in General Settings. Use the browse button to select a different grid or image format; see Application Notes for more details. Script Parameter: GRIDCOPY.IN |
Output grid |
Select the output grid file name. When multiple input grids or images are selected, this field will become inactive, and the output files will inherit the names of the input files. The default format for the output grid is set in General Settings; however, you can select a different grid or image format in the browse dialog. You can use this option very selectively, for instance, to convert band 2 of an ER Mapper grid to a Geosoft format grid. Script Parameter: GRIDCOPY.OUT |
Output format |
The default format is the Geosoft grid; however, you can select a different format from the drop down list. When a single input grid or image is specified, this field will become inactive: to specify a different output format, use the browse button beside the Output grid field to open the browse dialog and select the desired file type. Script Parameter: GRIDCOPY.OUT_FORMAT |
Output file prefix |
Specify the prefix that will appended to the file names. If left blank, the output files will inherit the names of the input files. Script Parameter: GRIDCOPY.OUT_PREFIX |
Output folder |
Select the output location where the files will be placed. By default, this points to the project folder; however, you can specify a different location. If the folder does not exist, you will be asked to confirm creating the folder. Script Parameter: GRIDCOPY.OUT_FOLDER |
Display option |
Use the drop-down list option "Display grid" if you want the generated grids to be displayed in the current project workspace as individual grid files. If the option "Do not display" is selected, the grids are added to the current project and listed in Project Explorer, but they will not be opened in the project workspace. Script Parameter: GRIDCOPY.DISPLAY_OPTION ["Do not display" (default), "Display grid"] |
Overwrite existing files |
Check this option to overwrite existing files. If the option is not checked, the copy/conversion is skipped for the files that already exist in the specified output folder. Script Parameter: GRIDCOPY.OVERWRITE |
For a list of supported grid and image formats see the topic Supported Data Formats.
Converting Grids to Image Files
When converting a data grid (e.g., *.grd or *.ers) to a GeoTIFF COLOR (*.tif) image file, the colour display (colour scheme and distribution) of the grid will be preserved in the output file. (The ITR of the grid is used for the colour conversion, and the information is saved in the associated GI file (*.gi) of the output image.)
If you want to convert a data grid to a Geosoft COLOR Grid (*.grd) image file while retaining the colour display of the data grid, you should use the Map > Export option.
Most standard image formats do not natively support non-EPSG datums. As a result, when converting from native Geosoft grids to other standard image formats, only EPSG datums are properly translated; custom or local projections will be ignored in these instances.
Converting an ER Mapper Grid with Separate Bands
If the input grid is an ER Mapper file, you can type the file name followed by the file type and band number in the following format:
Gridname.ERS(ERM;band=1)
Converting Image Files to Grids
1, 8, and 16-bit raster GeoTIFF files are supported and converted to the Geosoft raster RGB format. See the table below for more information.
GOCAD Gsurf 32-bit format support
The Gocad Gsurf format supports many layers. However, the copy/convert option allows you to convert only one layer to the Geosoft grid format. To specify the layer of the Gocad file to import, append the qualifier PROP=layer_number to the input file name upon selecting the Gocad Gsuf 32-bit format and prior to running the conversion. If the layer is not specified, the first layer is converted.
For example, the syntax for specifying the 2nd layer of the Gocad Gsurf file input.grs is: input.grs(GRS;PROP=2).
The Gocad Gsurf 32-bit format supports Point and Cell aligned registrations. On export, the Gocad image is cell centered by default. To specify a point centered (0) or explicitly specify a cell centered (1) registration, use the CELLS qualifier.
For example, the syntax for specifying a point aligned Gocad Gsurf file named output is: output.grs(GRS;CELLS=0).
The imported data is automatically assigned a 3D orientation and will automatically orient itself in a 3D view.
Converting between Floating Point GeoTIFFs* and Geosoft Grids
- Geolocated GeoTIFF Floating Point (.tif) file types can be converted to any of the supported grid formats.
When converting from a GeoTIFF Floating Point to a Geosoft grid, the floating-point values are retained. You can then control how to render the Geosoft grid. - The supported grid formats can be converted to both regular and cloud-optimized floating point GeoTIFFs by selecting the file type GeoTIFF Floating Point (.tif) or COG GeoTIFF Floating Point (.tif), respectively. When converting from a Geosoft grid to a GeoTIFF Floating Point, the assigned Photometric tag is set to grey scale, but the actual floating-point values are retained. As a result, if the output is viewed as a GeoTIFF, it will be rendered in grey scale. Location and orientation are preserved when converting from grids, including oriented plan and section grids, to floating point GeoTIFFs.
*The floating point GeoTIFF format has been widely adopted as a standard. For a quick look at the two GeoTIFF format options, see
A
Cloud-optimized GeoTIFFs, however, are not yet supported on import.
GeoTIFFs (raster and floating point) – supported formats:
Byte size |
Bit size |
Type |
Description |
Notes |
| xx | 1 | Image | Black & white | Converted to tiff RGB for display |
| 1 | 8 | Image | Gray scale image | Converted to 8-bit tiff RGB for display |
| 1 | 8 | Image | Colour RGB/CMYK image | CMYK converted to tiff RGB for display |
| 2 | 16 | Image | Colour image | Converted (remapped) to 8-bit RGB for display |
| 4 | 32 | Floating Point | Magnitude | Converted to/from grid |
| 4 | 32 | Floating Point | Export to COG data | COG-supported conversion from grid (export) |
