General Settings
Use the Project > Settings > General menu option (SETTINGS GX) to change the "general" default settings for your Oasis montaj environment.
These settings are global variables and remain set for a given installation of Oasis montaj. The values are stored in the 'geosettings' file located in the user-specific folder '%USERPROFILE%\Documents\Geosoft\Desktop Applications \ini'. This means they remain consistent across different data sets and Oasis montaj projects. Restart Oasis montaj for the changes to take effect.
General Settings dialog options
Default project directory |
The default location for your projects is set under your user profile Documents folder: %USERPROFILE%\Documents\Geosoft Projects. The subdirectory "Geosoft Projects" will be created if it does not exist. Use the browse [...] button to select a different location for your project directory. New projects will be created under the selected parent folder. |
Select the menu files (*.omn) to load as the default menus when creating a new project. If more than one menu is selected, each menu must be separated by the | character. Example: coremenus.omn|magmap.omn
Script Parameter: SETTINGS.DEFAULT_MENU |
The default colour scheme for rendering the image of grids is initially set to the colour.tbl file. To modify the selection, click on the colour entry and then navigate through the scheme categories. Mouse over the colour scheme entry to display the file name (and file location) of the current default colour scheme.
Script Parameter: SETTINGS.DEFAULT_COLOUR |
Select the default colour scheme for rendering the image of symbols. If you mouse over the colour scheme entry, a tooltip will display the name of the colour table in its folder. To modify the selection, click on the colour entry and then navigate through the scheme categories. Script Parameter: SETTINGS.DEFAULT_MAP_FONT |
Set a preferred default colour distribution method for your project. Select the default colour method for rendering colour distributions as one of the following options:
All your displayed grids in your project will now use this colour distribution method.
Script Parameter: SETTINGS.DEFAULT_COLOUR_METHOD |
Default distance unit |
Select the default ground distance unit (e.g., metre, kilometre, centimetre, foot, etc.) Script Parameter: SETTINGS.DEFAULT_UNIT |
Default map font |
Select the default map font. The configuration settings file 'truetype.ini' will be modified to map the "default" font from Geosoft PLT files to the TRUETYPE font specified here. You can modify the 'truetype.ini' file to change the mappings of other fonts.
Script Parameter: SETTINGS.DEFAULT_SYMBOL_FONT |
Default symbol font |
Select the default symbol font (*.gfn) for selecting plot symbols. Script Parameter: SETTINGS.DEFAULT_SYMBOL_FONT |
Specify the default type of compression to use when creating a new database. There are three options:
Script Parameter: SETTINGS.COMPRESSION |
Select the text file editor program to use to view and modify text files. You can also set the editor through the Select a Default Text Editor dialog.
[Next] |
Click Next to continue with more settings. |
More Settings dialog options
Select the input grid format you would like to use by default. Script Parameter: SETTINGS.DEFAULT_XGD_IN |
Select the output grid format you would like to use by default. Script Parameter: SETTINGS.DEFAULT_XGD_OUT |
Specify the default option to use when creating a Geosoft grid. There are two options:
The 16-bit (DOS compatible) option is no longer supported because of unintended consequences (e.g. loss of precision) for internal computations and output grids. If you had it selected previously in your settings, it will be automatically changed to the 32-bit floating-point option.
Use the Copy/Convert Grid GX to generate a 16-bit (DOS compatible) grid, if needed. 16-bit (DOS compatible) grids are, however, supported as inputs to our GXs. Script Parameter: SETTINGS.XGD_DEFAULT |
Load last project? |
When you start Oasis montaj, you are prompted to select a project to open. Change this option to Yes, and the last project you were working with will open automatically. |
Confirm database saves? |
If the option Yes is preserved, when you close a project, you will be asked if you want to save any open databases. If you select No, the database(s) will be saved automatically. Script Parameter: SETTINGS.CONFIRM_GDB_SAVE |
Specify coordinate system on import? |
Select if you would like to be prompted for coordinate system information on import. If Yes is selected, when importing to a database and there is no projection specified in the current X and Y channels, Set Coordinate System is run so that you can set up the projection. Some imports do their own specification of projection and are not affected by this setting.
Script Parameter: SETTINGS. NEW_GDB_PROJECTION |
Error report level |
Select the message level you want to see. If All errors is selected, you will see more error messages each time an error occurs. This is useful when contacting Script Parameter: SETTINGS.ERROR_LEVEL |
Oasis montaj provides the ability to nest your saved print files (*.PRN) for HP-RTL printing. Set the HP-RTL nesting option to "on" to enable the plotting of multiple maps on a single map sheet. When you enable or disable nesting on an HP-RTL printer: the "INIT" parameter in the [HPRTL] section is set to the "INIT_NEST" or "INIT_NONEST" value respectively.
Script Parameter: SETTINGS.HPRTL_NESTING (0: off (default), 1: on) |
Temporary file directory |
This directory is used by Oasis montaj to store temporary files. Depending on the application, the storage requirements for this directory can be very large (ranging from 10 megabytes to gigabytes). We recommend setting this parameter to a very fast drive to improve performance of all large data operations (e.g., MAGMAP filtering, gridding, etc.) Oasis montaj cannot start if this drive is invalid or if it is set to a drive where it cannot create files. Please ensure that the directory is always valid.
In previous versions of Oasis montaj, the GEOTEMP environment variable determined where this directory was stored. This variable is no longer used, and the setting is now controlled through the Windows registry. When a Seequent Evo process (Import, Publish) is initiated for the first time, an Evo folder is created at the root of this directory. This folder will contain the log file, which is updated for each Evo session, along with individual cache folders generated for each import or publish session. |
