XYZ to Voxel
Use the Voxel > Conversions > XYZ to Voxel menu option (geogxnet.dll(Geosoft.GX.VoxUtils.ImportXYZToVox;Run)*), to import an XYZ file to a Geosoft Voxel.
XYZ to Voxel dialog options
XYZ file |
Browse to select the XYZ file to import. Script Parameter: IMPORTXYZTOVOX.XYZ_FILE |
Output voxel |
Specify the name of the Geosoft Voxel file to generate (.geosoft_voxel) Script Parameter: IMPORTXYZTOVOX.OUTPUT_FILE |
Coordinate System
Coordinate System |
The Coordinate System dialog allows you to specify the correct coordinate system information (Datum and Projection Method) for the incoming XYZ file. Script Parameters:
The import does not do gridding. The data must already be in a rectangular grid form.
The import does support non-uniform cell sizes as long as all the cell sizes can be determined. See GDB to Voxel for information on how non-uniform voxels can be imported.
If a 3D Viewer is open during the import, then the output voxel will be displayed in that 3D view. Otherwise, the output voxel will be displayed into a new Voxel Viewer window.
If the output voxel does not display, open the Advanced Settings dialog (Project > Settings > Advanced) and under the Voxel Settings section, check if the Display Created Voxels option is set to "True".
