SEG-Y Key Field Locations
Use the SEG-Y Key Field Locations dialog to verify or provide the critical information that will allow the selected SEG-Y file to be read properly. In most cases, the correct fields will be automatically detected and those values displayed.
After this dialog is closed, the entire file will be scanned to determine the data ranges.
SEG-Y Key Field Locations dialog options
The SEG-Y Standard(s) specify the locations and format of the information in the file. In most cases, the correct locations will be detected and, if available, the correct values displayed. However, values may be incorrect or missing or the trace format incorrect. You may change the Binary or Trace Header locations that are used for most values, and in most cases you may enter your own value if required.
Vertical Units
If the vertical axis is time, all values in the file, with the exception of the sample interval, will be in milliseconds (ms); the sample interval is expected to be given in µs. If the vertical axis is depth, the vertical units will be meters or feet, depending upon the unit system specified in the Binary Header, and the sample interval will be in milli-meters or milli-feet. The value is essentially biased by 1000x so that fractional values may be stored as an integer. In some cases the sample interval may not be biased in this way and you may change the units drop-down to reflect this.
