Import SEG-Y
Use the 3D View > Import SEG-Y menu option (geogxnet.dll(Geosoft.GX.SegY.ImportSegy;Run)*), to import SEG-Y files.
This is the first dialog in the SEG-Y Import wizard. Select the SEG-Y file that you wish to import, specify whether it is a 2D profile or a 3D volume, and specify whether its vertical dimension is "Depth" or "Time". If it is a 3D volume, you may also specify a pre-existing survey file that maps Inline & Crossline coordinates to X & Y.
Import SEG-Y dialog options
The SEG-Y Standards (Rev. 0 & 1) specify the appropriate locations for information and the data formats used to store them. However, the specifications are not rigidly followed, and files are written using many, often poorly-documented variations. For instance, the standard states that all trace headers should be written as 2- or 4-byte integer values, but some fields may be stored as floating point values. This wizard and the Trace Viewer are designed to follow the standard but also to allow flexibility in how an SEG-Y file is read, should exceptions be encountered.
