Create Multiple Isosurfaces from Voxel
Use the Create Multiple Isosurfaces from Voxel option (geogxnet.dll(Geosoft.GX.VoxUtils.VoxelSurfaceMultiple;Run)*), to create a single geosurface file with multiple isosurfaces extracted from a single voxel. A new Geosurface file will be created and added to the Project Explorer. If a 3D View is open, the geosurface will be added to the 3D Viewer.
You can access the option from:
The Oasis montaj Geosurface > New > Create Multiple Isosurfaces from Voxel menu
The Oasis montaj 3D View > Geosurface > Isosurface > Create Multiple Isosurfaces from Voxel menu
The 3D Viewer Geosurface > Isosurface > Create Multiple Isosurfaces menu
Create Multiple Isosurfaces from Voxel dialog options
A 3D surface that passes through points of equal value is called an isosurface. Isosurfaces can be thought of as 3D contours and can be used to visualize grade shells, or other volumes of interest.
When using the "Open option", it is still possible to have a closed isosurface generated as the output surface, if the data forms a closed isosurface at the chosen value. Choosing the "Closed option", however, will force the output surface to be closed around any undefined areas (such as where the surface meets the edges of the voxel, or where the surface meets an area of null values). When creating multiple isosurfaces, the closed surfaces will each close around values that are between two specified values, depending on the option selected.
The surface is calculated using an implementation of the "Marching Cubes Algorithm" originally developed by Lorensen and Cline 1.
Reference
- [1] Lorensen, W.E, and Cline, Harvey E., "Marching Cubes: a High Resolution 3D Surface Construction Algorithm", Computer Graphics, vol. 21, no. 4 (1987, July).
