Array To Database Channels
Use the Database Tools > Array Channels > Array To Database Channels menu option (geogxnet.dll(Geosoft.GX.Database.ArrayToChannels;Run)*) to select an Array channel to be displayed as standard database channels.
Array To Database Channels dialog options
Array channel
Using the Array channel drop-down list, select an Array channel from your current database.
Array channel elements
The array channel elements for your selected array channel are displayed in the Array channel elements list.
Database channels
The individual channels from your selected array channel are displayed in the Database channels list.
[Add]
Select (highlight) the array channel elements to be displayed as standard database channels. Click the Add -> button to move the selected array channel elements to the Database channels list.
[Remove]
Select (highlight) the database channels to be removed. Click the <- Remove button to move the selected database channels to the Array channel elements list.
