High-pass Filter
Use the High-pass option to apply a Fast-Fourier Transform High-pass filter to a channel.
High-pass filter options
Wavelength cutoff
(in ground units)
Wavelength cutoff value (in ground units) Enter 0 for an infinitely long wavelength (Default is 0).
Script Parameter: FFTHIGHP.WAVEL
High-pass Filter
Parameter:
k0 The cutoff wavenumber in cycles/ground_unit. All wavenumbers above this value are removed.
Ground_unit is the survey ground units used in your grid (eg. metre, feet etc.).
As with the band-pass filter, the low-pass filter is seldom used because the results usually suffer from Gibb's Phenomena (ringing).
