Save Section Grid(s) to Database
Use the Section Tools > Save Section Grid(s) to Database menu option (geogxnet.dll(Geosoft.GX.Database.SectionGridsToDatabase;Run)*), to import gridded section data into a new or existing database.
Save Section Grid(s) to Database dialog options
This GX accepts gridded section file(s) as input and saves them into a database as an array channel. The geo-referenced X & Y, and optionally the elevation, are saved as data channels in the same database. The elevation channel contains the first non-dummy value found in each grid.
