Eötvös Correction
Use the Moving Platform Gravity > Corrections by Steps > Eötvös Correction menu option, (geogxnet.dll(Geosoft.GX.Gravity.EotvosCorrection;Run)*), to calculate the Eötvös correction.
Eötvös Correction dialog options
Earth’s rotation produces outward centrifugal acceleration. Objects moving across the rotating Earth experience additional acceleration related to their east-west velocity, with the effects strongest at the equator and decreasing with latitude.
A body moving east (in the direction that Earth spins) experiences an increase in centrifugal acceleration.
A body moving west experiences decreased centrifugal acceleration.
The vertical component of this acceleration and a small acceleration related to the motion of the curved Earth are known as the Eötvös effect. This effect can be as large as 30 milligals (mGal) and should be accounted for in moving platform surveys.
The Eötvös effect is defined as:
The first term corresponds to the Eötvös effect; the second term is a refinement, which is much smaller in amplitude. To take into account Earth’s ellipsoidal shape, R can be expanded into Earth’s major axis, Earth’s flattening, the latitude, and the observation height to yield the Exact equation below. Two other published variations for the Eötvös effect are also offered.
[Exact]:
[Harlan, 1968]1:
[Glicken, 1962]2:
Where:
E
Eötvös correction (milligals)
R
Earth’s radius at latitude φ
V
Velocity in knots
Ws
Angular velocity of Earth’s rotation = 7.2921158533E-5 rad/s
α
Heading (direction of movement of the vehicle, measured clockwise from true north)
ε
Earth’s eccentricity = (ra-rb) / ra
φ
Latitude of the vehicle
h
Observation height (height above geoid)
ra
Earth’s major axis = 6378137.0 m
rb
Earth’s minor axis = 6356752.3141 m
νe and νn
Velocities in easting & northing directions calculated from the heading and velocity channels
References
- R. B. Harlan, "Eötvös corrections for airborne gravimetry", Journal of Geophysical Research, vol 73, no 14 (July 15, 1968).
- M. Glicken, "Eötvös corrections for a moving gravity meter", Geophysics, vol 27, no 4 (1962), pp. 531-533.
