Copy/Convert Grid(s)
Use the Grid and Image > Utilities > Copy/Convert Grid(s) menu option (geogxnet.dll(Geosoft.GX.GridUtils.CopyConvertMultiGrids;Run)*) to copy or convert grids/images from/to other standard grid/image formats.
Copy/Convert Grid(s) dialog options
Input grid(s)
Select the input grid(s). The default format is the input grid format set in General Settings. Use the browse button to select a different grid or image format; see Application Notes for more details.
Script Parameter: GRIDCOPY.IN
Output grid
Select the output grid file name. When multiple input grids or images are selected, this field will become inactive, and the output files will inherit the names of the input files.
The default format for the output grid is set in General Settings; however, you can select a different grid or image format in the browse dialog. You can use this option very selectively, for instance, to convert band 2 of an ER Mapper grid to a Geosoft format grid.
Script Parameter: GRIDCOPY.OUT
Output format
The default format is the Geosoft grid; however, you can select a different format from the drop down list. When a single input grid or image is specified, this field will become inactive: to specify a different output format, use the browse button beside the Output grid field to open the browse dialog and select the desired file type.
Script Parameter: GRIDCOPY.OUT_FORMAT
Output file prefix
Specify the prefix that will appended to the file names. If left blank, the output files will inherit the names of the input files.
Script Parameter: GRIDCOPY.OUT_PREFIX
Output folder
Select the output location where the files will be placed. By default, this points to the project folder; however, you can specify a different location. If the folder does not exist, you will be asked to confirm creating the folder.
  • When the output folder field is left blank, the output grids always default to the project folder even if the grids reside in a different location.
  • Script Parameter: GRIDCOPY.OUT_FOLDER
    Display option
    Use the drop-down list option "Display grid" if you want the generated grids to be displayed in the current project workspace as individual grid files.
    If the option "Do not display" is selected, the grids are added to the current project and listed in Project Explorer, but they will not be opened in the project workspace.
  • The default option "Do not display" overrides the Advanced Settings attribute, Image Settings > Display Created Grids, when its value is set to "True".
  • Script Parameter: GRIDCOPY.DISPLAY_OPTION ["Do not display" (default), "Display grid"]
    Overwrite existing files
    Check this option to overwrite existing files. If the option is not checked, the copy/conversion is skipped for the files that already exist in the specified output folder.
    Script Parameter: GRIDCOPY.OVERWRITE
    For a list of supported grid and image formats see the topic Supported Data Formats.
    Converting Grids to Image Files
    When converting a data grid (e.g., *.grd or *.ers) to a GeoTIFF COLOR (*.tif) image file, the colour display (colour scheme and distribution) of the grid will be preserved in the output file. (The ITR of the grid is used for the colour conversion, and the information is saved in the associated GI file (*.gi) of the output image.)
    If you want to convert a data grid to a Geosoft COLOR Grid (*.grd) image file while retaining the colour display of the data grid, you should use the Map > Export option.
    Most standard image formats do not natively support non-EPSG datums. As a result, when converting from native Geosoft grids to other standard image formats, only EPSG datums are properly translated; custom or local projections will be ignored in these instances.
    Converting an ER Mapper Grid with Separate Bands
    If the input grid is an ER Mapper file, you can type the file name followed by the file type and band number in the following format:
    Gridname.ERS(ERM;band=1)
  • Only one of the files can be in ER Mapper format. You cannot directly convert one ER Mapper file to another.
  • Converting Image Files to Grids
    1, 8, and 16-bit raster GeoTIFF files are supported and converted to the Geosoft raster RGB format. See the table below for more information.
    GOCAD Gsurf 32-bit format support
    The Gocad Gsurf format supports many layers. However, the copy/convert option allows you to convert only one layer to the Geosoft grid format. To specify the layer of the Gocad file to import, append the qualifier PROP=layer_number to the input file name upon selecting the Gocad Gsuf 32-bit format and prior to running the conversion. If the layer is not specified, the first layer is converted.
    • For example, the syntax for specifying the 2nd layer of the Gocad Gsurf file input.grs is: input.grs(GRS;PROP=2).
    The Gocad Gsurf 32-bit format supports Point and Cell aligned registrations. On export, the Gocad image is cell centered by default. To specify a point centered (0) or explicitly specify a cell centered (1) registration, use the CELLS qualifier.
    • For example, the syntax for specifying a point aligned Gocad Gsurf file named output is: output.grs(GRS;CELLS=0).
    The imported data is automatically assigned a 3D orientation and will automatically orient itself in a 3D view.
    Converting between Floating Point GeoTIFFs* and Geosoft Grids
    • Geolocated GeoTIFF Floating Point (.tif) file types can be converted to any of the supported grid formats.
      When converting from a GeoTIFF Floating Point to a Geosoft grid, the floating-point values are retained. You can then control how to render the Geosoft grid.
    • The supported grid formats can be converted to both regular and cloud-optimized floating point GeoTIFFs by selecting the file type GeoTIFF Floating Point (.tif) or COG GeoTIFF Floating Point (.tif), respectively. When converting from a Geosoft grid to a GeoTIFF Floating Point, the assigned Photometric tag is set to grey scale, but the actual floating-point values are retained. As a result, if the output is viewed as a GeoTIFF, it will be rendered in grey scale. Location and orientation are preserved when converting from grids, including oriented plan and section grids, to floating point GeoTIFFs.
    *The floating point GeoTIFF format has been widely adopted as a standard. For a quick look at the two GeoTIFF format options, see Raster and Floating Point GeoTIFFs: What is the difference? NASA Earth Observations (NEO).
    A Cloud Optimized GeoTIFF (COG) is a tiled floating point GeoTIFF intended to optimize the targeted access to GeoTIFF data. This new data delivery format improves processing time, storage, and supports new and evolving cloud processing capabilities.
    Cloud-optimized GeoTIFFs, however, are not yet supported on import.
    GeoTIFFs (raster and floating point) – supported formats:
    Byte size
    Bit size
    Type
    Description
    Notes
    xx 1 Image Black & white Converted to tiff RGB for display
    1 8 Image Gray scale image Converted to 8-bit tiff RGB for display
    1 8 Image Colour RGB/CMYK image CMYK converted to tiff RGB for display
    2 16 Image Colour image Converted (remapped) to 8-bit RGB for display
    4 32 Floating Point Magnitude Converted to/from grid
    4 32 Floating Point Export to COG data COG-supported conversion from grid (export)
