UBC to Voxel
Use the Voxel > Conversions > UBC to Voxel menu option (geogxnet.dll(Geosoft.GX.VoxUtils.ImportUBCToVox;Run)*), to import UBC 3D Model & Mesh files to a Geosoft Voxel.
UBC Mesh Tools 3D Model to Voxel dialog options
Output voxel
Specify the name of the Geosoft Voxel file to generate (.geosoft_voxel).
Script Parameter: IMPORTUBCTOVOX.OUTPUT_FILE
Model file
Browse to select the UBC Model file to import.
Script Parameter: IMPORTUBCTOVOX.MODEL_FILE
MSH Header file
Specify the Mesh file (*.msh) containing a description of the 3D mesh. See below for the format.
Script Parameter: IMPORTUBCTOVOX.MSH_HEADER_FILE
Dummy value
Specify a value to be interpreted as dummy in the import.
Script Parameter: IMPORTUBCTOVOX.DUMMY_VALUE (default -9.0)
  • There is no fixed dummy value in UBC mod files; it is normally set as -9.0, but it can be -90.0– for instance if there is real data smaller than -9.0.s.
  • Coordinate System
    Coordinate System
    The Coordinate System dialog allows you to specify the correct coordinate system information (Datum and Projection Method) for the incoming UBC 3D Model/MSH file.
    Script Parameters:
    • IMPORTUBCTOVOX.IPJ_NAME
    • IMPORTUBCTOVOX.IPJ_DATUM
    • IMPORTUBCTOVOX.IPJ_METHOD
    • IMPORTUBCTOVOX.IPJ_UNITS
    • IMPORTUBCTOVOX.IPJ_LOCALDATUM
    If a 3D Viewer is open during the import, then the output voxel will be displayed in that 3D view. Otherwise, the output voxel will be displayed into a new Voxel Viewer window. If the output voxel does not display, open the Advanced Settings dialog (Project > Settings > Advanced) and under the Voxel Settings section, check if the Display Created Voxels option is set to "True".
    MSH Header File Format
    This file contains the 3D mesh which defines the model region.
    The mesh has the following structure:
    NE NN NV
    E0 N0 V0
    ?E1 ? E2 ... ? ENE
    ? N1 ? N2 ... ? NNN
    ?V1 ? V2 ... ? VNV
    NE  Number of cells in the East direction.
    NN  Number of cells in the North direction.
    NV  Number of cells in the vertical direction.
    E0, N0, V0  Coordinates, in meters, of the southwest top corner, specified in (Easting, Northing, Elevation).
    Model File Format
    Model files consist of a total of NE*NN*NV values - one per line.
    Example:
    -9.0000000e+000
    -9.0000000e+000
    1.0607292e+001
    1.0642567e+001
    1.0762947e+001
    1.0782325e+001
    1.0803412e+001
    1.0837755e+001
    etc...
    File structure of model .sus:
    sus1,1,1
    sus1,1,2
    sus1,1,NV
    sus1,2,1
    susi,j,k
    susNN,NE,NV
    susi,j,k susceptibility at location [i j k].
    [i j k]=[1 1 1] is defined as the cell at the top-south-west corner of total number of lines in this file should equal NN NE NV, where NN is the in the North direction, NE is the number of cells in the East direction, and NV cells in the vertical direction. The lines must be ordered so that k changes the 1 to NV), followed by j (from 1 to NE), then followed by i (from 1 to NN).
    The dummy value is -9.0, and is automatically converted to a Geosoft dummy on import.
    The above descriptions are derived from the following document: MAG3D
    A Program Library for Forward Modelling and
    Inversion of Magnetic Data over 3D Structures
    VERSION 3.0
    Developed under the consortium research project
    JOINT/COOPERATIVE INVERSION OF
    GEOPHYSICAL AND GEOLOGICAL DATA
    UBC–Geophysical Inversion Facility
    Department of Geophysics and Astronomy
    University of British Columbia
    Vancouver, British Columbia
