Import GOCAD Surface(s)
Use the Imports > GOCAD Surface(s) option (geogxnet.dll(Geosoft.GX.Map.ImportGOCADSurface;Run)*) from the 3D Viewer > Add to 3D menu to import a GOCAD surface file into a Geosoft surface (geosurface) file.
A new geosurface file can be created, or the GOCAD surface can be appended to an existing geosurface file. The geosurface file is added to the current project (Project Explorer > Geosurfaces) and to the current 3D View.
Import GOCAD Surface(s) dialog options
GOCAD surface(s)
Select one or more GOCAD files to import and display.
Script Parameter: IMPGOCADSURFACE.FILE (Separate files with the "|" character).
Geosurface file
Specify the name of the geosurface file (*.geosoft_surface). Automatically pre-populated with the same file name as the input file.
Script Parameter: IMPGOCADSURFACE.SURFACEFILE
Invert Z values
The default is Z+ up. If your GOCAD t-surface is set to have Z- down, then select this option to invert the surface in the 3D View.
Script Parameter: IMPGOCADSURFACE.INVERT_Z (0: No (default), 1: Yes)
Import file
The output will be saved to a new or existing geosurface file. The new or existing geosurface will be displayed in the 3D View.
Script Parameter: IMPGOCADSURFACE.GEOSURFACE_EXISTING (0: Create new (default), 1: Append)
GOCAD Coordinate System
Coordinate system
The Coordinate System dialog allows you to specify the correct coordinate system information for the incoming GOCAD file. Use the drop-downs to define a coordinate system for the GOCAD surface file. The GOCAD coordinates will be re-projected from this coordinate system to the 3D View coordinate system if necessary. If multiple GOCAD files are selected, the specified coordinate system will be applied to all files.
Script Parameters:
IMPGOCADSURFACE.IPJ_NAME
IMPGOCADSURFACE.IPJ_DATUM
IMPGOCADSURFACE.IPJ_METHOD
IMPGOCADSURFACE.IPJ_UNITS
IIMPGOCADSURFACE.IPJ_LOCALDATUM
The colours specified in the GOCAD surface file will be used in the display. These can be edited in the Attributes tab.
  • When converting a GOCAD surface to a Geosoft geosurface, the inherent unit of measure stored in the GOCAD surface will not be used. Therefore, surface area or volume calculations in the Properties dialog in the Attributes tab may be interpreted incorrectly.
  • *GX.NET tools are embedded in the geogxnet.dll file located in the \Geosoft\Desktop Applications\bin folder. To run this GX interactively (outside the menu), first navigate to the bin directory and provide the GX.NET tool in the required format. See the Run GX topic for more guidance.
