Regrid a Voxel
Use the Voxel > New > Regrid a Voxel menu option (geogxnet.dll(Geosoft.GX.VoxUtils.RegridAVoxel;Run)*) to regrid an existing voxel at a different cell size.
Regrid a Voxel dialog options
Input voxel
The name of an existing voxel file to be regridded.
Script Parameter: REGRID_VOXEL.INPUT_VOXEL
Output voxel
The name of the output regridded voxel file.
Script Parameter: REGRID_VOXEL.OUTPUT_VOXEL
Interpolation method
Select the interpolation method.
Script Parameter: REGRID_VOXEL.INTERP_METHOD [0- Linear (default), 1- Nearest]
Mesh Specification
Regrid to existing voxel
If this option is selected, you must specify an overlapping voxel model.
Script Parameter: REGRID_VOXEL.MESH_DEFINITION [0-default]
Mesh voxel
The name of an existing voxel file that is at least as large as the input voxel and overlaps with it. The XYZ cell sizes to which the voxel is regridded are acquired from this voxel model.
Script Parameter: REGRID_VOXEL. MESH_VOXEL
Or
User defined
If this option is selected, you have to specify the XYZ cell sizes. Variable cell sizes are not supported.
Script Parameter: REGRID_VOXEL.MESH_DEFINITION [1-user defined]
Make X and Y cell sizes equal
Check this box to automatically reset the Y cell size value to the input X cell size.
  • The total number of cells and dimensions of the output voxel are displayed at the bottom of the dialog.
  • Script Parameter: REGRID_VOXEL. EQUAL_XY [0-default]
    XYZ cells
    The fields are automatically initialized to the Input voxel cell sizes.
    Specify the desired cell sizes in the three axes for the regridded voxel. Use the button beside the X cell size field to reset the cell values to the default (optimal) cell sizes.
  • The total number of cells and dimensions of the output voxel are recalculated every time these values change.
  • Script Parameters: REGRID_VOXEL.X_CELLSIZE, REGRID_VOXEL.Y_CELLSIZE , REGRID_VOXEL.Z_CELLSIZE
    Remove rotation
    If the input voxel has a rotation about an axis, check this box if you want to remove the rotation in the output regridded voxel. This will change the origin and dimensions of the output voxel and re-align the rotated coordinate system.
  • The calculated number of cells and dimensions of the output voxel are not affected if the input voxel is not a rotated voxel.
  • Script Parameter: REGRID_VOXEL.REMOVE_ROTATION [0-default]
