Quality Control by Data Range
Use the Quality Control > By Data Range option, (geogxnet.dll(Geosoft.GX.IP.QCByDataRange;Run)*), to reject data values outside a user specified range.
Quality Control by Data Range dialog options
It is recommended to use this tool together with the 3D Array Plot in order to visually inspect the retained valid data points.
