Grid Data
Use the Euler 3D > Grid Data menu option (E3MGRGRD GX) to create a gravity or total field magnetic grid (.GRD) file using the minimum curvature gridding method.
Minimum Curvature Gridding dialog options
Channel to grid
Select a channel from the database to be gridded.
Script Parameter: E3MGRGRD.CHAN
Output grid
The output grid will be placed in this file. The type of file can be controlled using the Browse tool, which is accessible from the list button.
Script Parameter: E3MGRGRD.GRDNAME
Grid Cell size
Specify the grid cell size. This should normally be ¼ to ½ the nominal data sample interval. If not specified, the data points are assumed to be evenly distributed and the default cell size will be set to:
Script Parameter: E3MGRGRD.CS
Display grid in
new map ?
Display grid in a new map, the current map, or choose not to display the new grid.
Script Parameter: E3MGRGRD.NEW (0:Current, 1: New, -1 Do not display)
Minimum Curvature Gridding – Advanced Options
Channel to grid
(Display only) The select channel to be gridded.
Name of new
grid file
(Display only) The selected output grid.
Grid Cell size
Specify the grid cell size. The grid cell size is in the distance units of the data. We recommend a cell size of ¼ to ½ the nominal data sample interval. The default is one quarter the average data separation based on a statistical average. A smaller cell size may be required if the data is to be contoured (we recommend 2 mm. or 1/10 inch at plot scale for contouring). This can be achieved by specifying a smaller cell size and larger desampling factor (desamp), or by regridding the grid using BIGRID.
Xmin, Ymin,
Xmax, Ymax
The minimum and maximum X and Y coordinates of the grid.
  • Leave this field blank to create a grid that covers the entire dataset.
  • To grid a subset of the data, specify the bounds of the desired rectangular area.
  • To default any value while preserving field order, use commas as placeholders.
    Example: ,#,#,# sets only Ymin, Xmax, and Ymax, with Xmin defaulting to its maximum extent plus the blanking distance.
If a blanking distance is not specified, the grid will extend to the data's maximum limits plus eight times the grid cell size.
Script Parameter: E3MGRGRD.XY
Low-pass
desampling factor
The desampling factor is defined as a function of the grid cell size. Prior to further calculations, all points within each cell (of dimensions cell_size × desampling_factor) are averaged into a single value, which is then assigned to the centre of the cell.
Script Parameter: E3MGRGRD.DSF
Blanking distance
All grid cells farther than the blanking distance from a valid point will be set to dummies in the output grid.
The default blanking distance is calculated as:
Preferably this parameter should be set to just greater than the maximum distance through which interpolation is desired.
Script Parameter: E3MGRGRD.BKD
Tolerance
Specify the allowable absolute error per grid cell (in grid data units). The default is 0.1% of the observed data's maximum range.Lowering the tolerance increases grid accuracy.
Script Parameter: E3MGRGRD.TOL
% pass tolerance
The minimum percentage of points that must meet the specified tolerance. The default is 99%. For a higher-quality grid, consider increasing this threshold.
Script Parameter: E3MGRGRD.PASTOL
Maximum iterations
Iterations at the finest coarseness level will stop when the maximum number or iterations is reached. At each greater coarseness, the maximum iterations is reduced by 2.
Increase this value if more iterations are required to produce a more accurate grid.
Script Parameter: E3MGRGRD.ITRMAX
Starting coarse grid
Select a value of 16, 8, 4, 2, or 1 to set the desired coarseness of the starting iteration level relative to the final grid cell size. By starting with a coarser grid, the algorithm is able to produce a reasonable result in under-sampled areas. As the coarseness decreases, the algorithm becomes more sensitive to local features. Only reduce the starting coarseness from 16 if faster processing time is required.
Script Parameter: E3MGRGRD.ICGR
Starting search
radius
Set the maximum search radius used to establish starting grid values for the coarse grid. Default: four times the coarse grid size set by the Starting coarse grid parameter. If no data is found within this radius, the mean of all data is used as the starting value. If the search radius is too small, the starting grid can be a poor approximation of the desired grid, resulting in excessive processing time. A radius that is too large may unnecessarily delay coarse grid generation.
Script Parameter: E3MGRGRD.SRD
Internal tension
(0-1)
The degree of internal tension (between 0 and 1). Default: 0, resulting in a true minimum curvature grid with no tension.Increasing tension can be used to prevent overshooting of valid data in sparse areas; however, curvature in the vicinity of real data will increase. In general, the sparser the areas in the data—with localized highs and lows— the higher the tension should be set.
Script Parameter: E3MGRGRD.TENS
Cells to extend
beyond data
Edge clipping parameter, the number of grid cells to extend beyond the outside limits of the data. The default (-1) is not to apply edge clipping to the blanking distanced grid. Use this parameter to ensure the grid does not extend too far beyond the actual data limits, which can occur when using a large blanking distance with widely spaced data.
Script Parameter: E3MGRGRD.EDGCLP
