Forward FFT
Use the FFT2IN GX to apply a Fast Fourier Transform to an image.
This step (GX) is already integrated into the MAGMAP Filtering option.
FFT2IN dialog options
Name of input pre-processed grid file
Specify the name of the input pre-processed grid file.
Script Parameter: FFT2.IN
A transform grid will be created using the root name of the input grid with extension (*.TRN). By default, this TRN grid will be created in the current working directory. This location can be changed in a script by setting the parameter:
FFT2IN.TRN="full path to grid file.ext(qual)"
A transform grid is a floating-point grid (4-byte reals), in which each pair of points represents the real and imaginary components of a Fourier Transform point. The data storage in transform file is as follows:
NX = original X dimension
NY = original Y dimension
DX = X element separation
DY = Y element separation
WX = 1/(NX*DX), wavenumber increment in X
WY = 1/(NY*DY), wavenumber increment in Y
QX = 1/(2*DX) , Nyquist in X
QY = 1/(2*DY) , Nyquist in Y
0 +WX +QX
r i r i r i
v NY-1 . . . . . . . . . . -WY
e . . . . . . . . . . -WY*2
c . . . . . . . . . .
t . . . . . . . . . .
o . . . . . . . . . .
r . . . . . . . . . .
. . . . . . . . . . -(QY-WY)
^ . . . . . . . . . . QY
| . . . . . . . . . . QY-WY
2 . . . . . . . . . . WY*2
1 . . . . . . . . . . WY
0 . . . . . . . . . . 0
0 1 2 (NX+1) -> element
(The X(-)Y(+) portion will be complex conjugate of the X(+)Y(-) portion)
(The X(-)Y(-) portion will be complex conjugate of the X(+)Y(+) portion)
