Bandpass (BPAS)
Use the Bandpass option to apply a bandpass filter.
Bandpass Filter dialog options
Long wavelength cutoff
The long wavelength cutoff in ground units. As shown in the illustration, this parameter corresponds to k0-1.
Short wavelength cutoff
The short wavelength cutoff in ground units. As shown in the illustration, this parameter is equivalent to k1-1.
Pass
Reject
Choose whether to pass or reject the defined band. The default setting is Pass.
The bandpass filter (BPAS) can be used to pass or reject a selected range of wavelengths within the data. However, applying a simple cutoff filter to an energy spectrum almost invariably introduces a significant amount of oscillation (Gibbs’ Phenomenon). This filter is included for completeness, but we recommend using a tapered filter such as the Butterworth filter (BTWR).
Bandpass Filter
Where:
k0
Low wavenumber cutoff (cycles per ground unit).
k1
High wavenumber cutoff (cycles per ground unit).
Wavenumber Domain Variable Definitions
The following variables are used in the wavenumber domain:
k
Wavenumber increment, used to depict a radially symmetrical variable.
Where:
np: number of points
cs: cell size
μ
X-component of the wavenumber.
v
Y-component of the wavenumber.
r
Radial component of the wavenumber.
θ
Angular (polar) component of the wavenumber.
  • Ground unit refers to the survey ground units defined in your grid (e.g., metres or feet). Ground units may also be left unspecified.
