Directional Cosine (DCOS)
Use the Directional Cosine option to apply a directional cosine filter.
Directional Cosine Filter dialog options
Cut-off azimuth
The direction of the filter, specified in degrees azimuth (clockwise from North) in the space domain. This parameter can be used to isolate or remove a predominant geological strike.
Degree of cosine function
The degree of the cosine function (n). By default, a degree of 2 is used, producing a cosine‑squared response.
Reject
Pass
Reject: Attenuates all wavenumbers in the specified direction.
Pass: Retains only the wavenumbers in the specified direction.
By default, the direction is rejected.
  • An inherent characteristic of FFT-based filtering is that, to counteract ringing artifacts near the cut-off wavelength, some of the signal intended for removal may inevitably leak into the filtered result.
  • Application Notes
    The directional cosine filter is used to isolate or remove signal oriented in the specified azimuth direction. The width of the rejection (or pass) notch can be adjusted by changing the degree of the cosine function so that highly directional features can be isolated more narrowly (see the filter figure below). Using a directional cosine filter instead of a straight directional pass/reject filter is recommended because it minimizes ringing artifacts associated with the discrete Fourier transform.
    A common application of this filter is the decorrugation of poorly levelled magnetic data. To remove this type of signal:
    1. Pass all signal along the azimuth angle perpendicular to the flight direction.
      The output will contain all wavelengths in this predominant direction.
    2. Apply a high-pass Butterworth filter to isolate wavelengths equal to or shorter than two line spacings.
      You may need to adjust the cut-off as necessary.
    3. The resulting output should contain the majority of the corrugation signal oriented normal to the flight lines.
    4. Subtract this grid from the original input grid to attenuate line-to-line corrugation.
  • In the wavenumber domain, the angle is referenced to the U-axis (α + 90°) (see figure below).
  • Directional Cosine Filter Illustration
    To reject direction α
    To pass direction α
    Wavenumber Domain Variable Definitions
    The following variables are used in the wavenumber domain:
    k
    Wavenumber increment, used to depict a radially symmetrical variable.
    Where:
    np: number of points
    cs: cell size
    μ
    X-component of the wavenumber.
    v
    Y-component of the wavenumber.
    r
    Radial component of the wavenumber.
    θ
    Angular (polar) component of the wavenumber.
