Directional Pass/Reject (DPAS)
Use the Directional Pass/Reject option to apply a directional pass/reject filter.
Directional Pass/Reject Filter dialog options
Starting cut-off azimuth
The low cut-off angle in degrees azimuth in the space domain (geological strike).
This angle is 90° offset from k0 in the frequency domain.
(Starting cut‑off azimuth = k0− 90°).
See the figure below for reference.
Ending cut-off azimuth
The high cut-off angle in degrees azimuth in the space domain (geological strike).
This angle is 90° offset from k1 in the frequency domain.
(Ending cut-off azimuth = k1− 90°).
Pass
Reject
Select to pass or reject the defined directional band.
By default, the band is passed.
Parameters:
k0
The low cut-off angle in degrees azimuth (from North)
k1
The high cut-off angle in degrees azimuth (from North)
0/1
1 = pass the defined band
0 = reject the defined band
(Default: 1, pass the band)
As with a standard bandpass filter (BPAS), the directional pass filter often exhibits Gibbs’ phenomenon due to the abrupt truncation of the spectrum. For this reason, the Directional Cosine (DCOS) filter is generally recommended, as its smooth cosine‑tapered response significantly reduces ringing associated with sharp spectral cut‑offs.
Wavenumber Domain Variable Definitions
The following variables are used in the wavenumber domain:
k
Wavenumber increment, used to depict a radially symmetrical variable.
Where:
np: number of points
cs: cell size
μ
X-component of the wavenumber.
v
Y-component of the wavenumber.
r
Radial component of the wavenumber.
θ
Angular (polar) component of the wavenumber.
