Pseudo-Gravity (GPSD)
Use the Pseudo-Gravity option to apply a pseudo-gravity filter.
Pseudo-Gravity Filter dialog options
Date (YYYY/MM/DD)
Enter the date when the survey was conducted. The geomagnetic inclination and declination of the IGRF field are automatically calculated and populated.
A Calculate button appears to the right of the date field after a valid date is entered.
This field is optional.
Inclination
Geomagnetic inclination (I), in degrees measured from the horizon.
Declination
Geomagnetic declination (D), in degrees azimuth.
Density contrast
Density contrast (d), in g/cm3. (Default = 1.0).
Magnetization
Magnetization (J), in nT. (Default = 50,000).
Amplitude correction inclination
Inclination Ia used for amplitude correction.
Default value: ±20°.
If | Ia | is entered as less than | I |, it is automatically set to I.
Typically, the input to this filter is a TMI (Total Magnetic Intensity) grid. However, you may also begin with a pole‑reduced grid.
In that case:
  • Set the inclination to 90°
  • Declination is irrelevant and may be set to 0°
Pseudo-Gravity Equation and Condition
if | Iɑ | < | I |, Iɑ = I
Where:
I
Geomagnetic inclination.
Iɑ
Inclination used for amplitude correction (never less than I). Default = ±20°.
If | Iɑ | < | I |, it is set to I.
d
Density contrast in g/cm3.
G
Gravitational constant (6.6738).
J
Magnetization in nT.
D
Geomagnetic declination.
Parameters:
q
Direction of the wavenumber, in degrees azimuth.
r
Wavenumber, in radians per ground unit.
r=2πk
Where k is in cycles per ground unit.
Wavenumber Domain Variable Definitions
The following variables are used in the wavenumber domain:
k
Wavenumber increment, used to depict a radially symmetrical variable.
Where:
np: number of points
cs: cell size
μ
X-component of the wavenumber.
v
Y-component of the wavenumber.
r
Radial component of the wavenumber.
θ
Angular (polar) component of the wavenumber.
Ground unit refers to the survey ground units defined in your grid (e.g., metres or feet). Ground units may be left undefined.
Output Units
Output pseudo‑gravity is:
  • mGal, if the ground unit is metres, or
  • 0.3 mGal, if the ground unit is feet.
