High-pass (HPAS)
Use the High-pass option to apply a high-pass filter to the data.
High-pass Filter dialog options
Cutoff wavelength |
The cutoff wavelength k0-1, in ground units. All wavelengths longer than this value are removed. |
A high-pass filter removes long-wavelength components while retaining shorter wavelengths.
The filter response is defined as:
| L(k) = 0 | for k < k0 |
| L(k) = 1 | for k ≥ k0 |
Where:
k = wavenumber
k0 = cutoff wavenumber
Wavenumber Domain Variable Definitions
The following variables are used in the wavenumber domain: |
k |
Wavenumber increment, used to depict a radially symmetrical variable. |
Where: np: number of points cs: cell size |
μ |
X-component of the wavenumber. |
v |
Y-component of the wavenumber. |
r |
Radial component of the wavenumber. |
θ |
Angular (polar) component of the wavenumber. |
Ground unit refers to the survey ground units defined in your grid (e.g., metres or feet). Ground units may be left undefined.
