Vertical Integration (INTGZ)
Use the Vertical Integration option to apply a vertical integration filter to the input data.
Vertical Integration dialog options
There are no configurable parameters for this filter.
Click OK to apply the vertical integration filter to the current grid.
The vertical integration filter calculates the vertical integral of the input transform. Mathematically, vertical integration is the inverse operation of the vertical derivative.
Because the vertical derivative amplifies high-frequency components and noise, vertical integration has the opposite effect: it attenuates high-frequency variations and enhances smoother, long-wavelength features.
During processing, the zero wavenumber component (k = 0) is explicitly set to zero to prevent undefined or infinite values in the transform domain.
The vertical integration operator is defined as:
L(r) = r-1
Wavenumber Domain Variable Definitions
The following variables are used in the wavenumber domain:
k
Wavenumber increment, used to depict a radially symmetrical variable.
Where:
np: number of points
cs: cell size
μ
X-component of the wavenumber.
v
Y-component of the wavenumber.
r
Radial component of the wavenumber.
θ
Angular (polar) component of the wavenumber.
Units and Conversion
To integrate Tzz in Eötvös to obtain mGal, multiply the MAGMAP output grid by:
100,000 × (scale factor to metres)
The scale factor depends on the spatial units of the grid.
For example, if the grid is defined in feet, use:
100,000 × 0.3048
