Integration along Y (INTGY)
Use the Horizontal Integration - Y option to integrate the field along the Y direction.
Horizontal Integration - Y dialog options
This filter has no user-defined parameters.
This filter integrates the input transform along the Y component. It performs the inverse operation of taking the derivative with respect to Y. The zero wavenumber is set to 0.
Integration Operator
L(v) = iv-1
Wavenumber Domain Variable Definitions
The following variables are used in the wavenumber domain:
k
Wavenumber increment, used to depict a radially symmetrical variable.
Where:
np: number of points
cs: cell size
μ
X-component of the wavenumber.
v
Y-component of the wavenumber.
r
Radial component of the wavenumber.
θ
Angular (polar) component of the wavenumber.
Ground unit refers to the survey ground units defined in your grid (e.g., metres or feet). Ground units may be left undefined.
