Low-pass (LPAS)
Use the Low-pass option to apply a low-pass filter to the data.
Low-pass Filter dialog options
Cutoff wavelength
The cutoff wavelength, k0-1, in ground units. All wavelengths shorter than this value are removed.
A low-pass filter can be used to pass or reject specific wavelength ranges within the data. However, applying a simple cutoff filter to an energy spectrum almost invariably introduces a significant amount of oscillation — commonly known as Gibbs’ Phenomenon. This filter is provided for completeness, but for most applications we recommend using a tapered filter such as the Butterworth filter (BTWR), which produces smoother results.
Low-pass operator
L(k) = 1 for k ≤ k0
L(k) = 0 for k > k0
Where:
k = wavenumber
k0 = cutoff wavenumber
Wavenumber Domain Variable Definitions
The following variables are used in the wavenumber domain:
k
Wavenumber increment, used to depict a radially symmetrical variable.
Where:
np: number of points
cs: cell size
μ
X-component of the wavenumber.
v
Y-component of the wavenumber.
r
Radial component of the wavenumber.
θ
Angular (polar) component of the wavenumber.
Ground unit refers to the survey ground units defined in your grid (e.g., metres or feet). Ground units may be left undefined.
