Free Air and Bouguer Anomaly
Use the Gravity > Free Air, Bouguer Anomaly menu option (geogxnet.dll(Geosoft.GX.Gravity.FreeAirAndBouguerAnomaly;Run)*) to carry out the following components of a gravity reduction:
(i) Free Air anomaly calculation
(ii) Bouguer anomaly calculation
(iii) Complete Bouguer anomaly (Bouguer anomaly + terrain correction)
Free Air and Bouguer Anomaly dialog options
Database |
The name of the current database (displayed for information only). |
Corrected gravity channel |
Select the gravity corrected channel (in milligals). Script Parameter: GRAVRED.GRAVITY |
Terrain correction |
Select the terrain correction channel. By default, if there is a channel named "Terrain" in the database, it will be selected. Script Parameter: GRAVRED.TCORCH |
Terrain correction density
The default terrain density (in g/cm³) is set to the last terrain density used to calculate the terrain effect. You can, however, override this density if necessary. Should you opt to calculate multiple Complete Bouguer anomalies in a single run, for each density, the terrain effect channel data is rescaled using the provided correction density prior to be added to the output gravity channel. It is important to note that if the terrain effect is calculated near bodies of water, the density variability is not taken into account. In such instances, for each density, the terrain correction must be calculated separately. See the Complete Bouguer Anomaly section in the Application Notes below.
Script Parameter: GRAVRED.TDENST |
Elevation channel |
Select the elevation channel. By default, if there is a channel named "Elevation" in the database, it will be selected. Script Parameter: GRAVRED.ELEVATION |
Output free air anomaly channel |
Specify the name of the output free air anomaly channel. Normally, this should be placed in channel "FreeAir"; however, you have the option of changing the name. Script Parameter: GRAVRED.FREEAIR |
Free air correction method |
Select an elevation correction formula from the list:
Additional elevation correction formulas can be defined and stored in the file named "Gravity_Free_Air.lst" located in the %USERPROFILE%\Documents\Geosoft\Desktop Applications \etc directory.
Script Parameter: GRAVRED.FREE_AIR |
Apply Bullard (Bullard B) |
Check this option to apply the curvature correction to the Bouguer anomaly. Script Parameter: GRAVRED.CURVATURE [1 – Yes (default) | 0 – No] |
Latitude channel |
This is a contextual parameter. If the Free air correction method selected is "Ellipsoid (Heiskanen & Moritz)", or the option Apply Bullard (Bullard B) correction is checked, you will be prompted to provide the latitude channel required for the free air correction. By default, if there is a channel named "Latitude" in the database, it will be selected. Script Parameter: GRAVRED.LATITUDE |
Output Bouguer anomaly |
Specify the name of the output Bouguer anomaly channel. Normally, this should be placed in channel "Bouguer". You have the option of changing the name in case you wish to create a number of Bouguer anomaly channels with different earth densities. Script Parameter: GRAVRED.BOUGUER |
Number of Bouguer corrections |
Specify the number of Bouguer corrections. The default is 1. If a number > 1 is entered, you will be prompted to enter a Minimum earth density and a Maximum earth density. Incremental densities will then be calculated, and for each density, a Bouguer correction and Bouguer anomaly will be calculated. The density used for the calculation will be appended to the name of the output channels. Display the Bouguer profiles for these channels, in the database profile window, to decide on the Bouguer correction to use and the optimal density that can best remove the terrain effect. See the Application Notes below for more details on Bouguer anomaly calculation.
Script Parameter: GRAVRED.CORRECTION_NUMBER |
Earth density (g/cc) |
Specify the density of the earth (in g/cm³) for calculating the Bouguer correction. Script Parameter: GRAVRED.DENSITY_EARTH |
Minimum earth density (g/cc) |
Specify the minimum density of the earth (in g/cm³) for calculating the Bouguer correction. Available when the Number of Bouguer corrections is > 1. Script Parameter: GRAVRED.DENSITY_EARTH_MIN |
Maximum earth density (g/cc) |
Specify the maximum density of the earth (in g/cm³) for calculating the Bouguer correction. Available when the Number of Bouguer corrections is > 1. Script Parameter: GRAVRED.DENSITY_EARTH_MAX |
Other layer |
Check this box if you wish to supply water/ice or overburden thickness and densities. Script Parameter: GRAVRED.OTHER_LAYER [1 – Yes (default) | 0 – No]
[More] |
Gravitational constant |
Over time, the gravitational constant changes ever so slightly. The default is set to the 2010 Gravitational constant in units of 10−11⋅m3⋅kg−1⋅s−2. See the Gravitational Constant section under Application Notes for further details.
Script Parameter: GRAVRED.GRAVITATIONAL_CONSTANT |
This GX assumes that:
a gravity database is currently loaded (see Import Gravity Survey).
the tide and drift corrections have been applied to produce absolute gravity (see Gravity Corrections).
the latitude, longitude ground locations are defined.
the latitude correction (the theoretical gravity at the station location) has been applied (see Latitude Correction).
the free air anomaly results will be stored in the "FreeAir" channel in the database.
the survey elevation data should be contained in an "Elevation" channel in the database.
1. Free Air Anomaly
The free air correction is calculated and added to the latitude corrected gravity. The expressions for the supported corrections are:
Where:
Hs
Station elevation in metres (relative to the datum, positive up)
L
Latitude of the station
The last formula accounts for the non-linearity of the free air anomaly as a function of both latitude and height above the geoid.
If you wish to provide alternate equation(s), define them in the file "Gravity_Free_Air.lst" located in the folder %USERPROFILE%\Documents\Geosoft\Desktop Applications \etc.
Each expression should be defined on one line, and it should consist of a unique name followed by the complete expression using the following syntax:
Where:
Input_Gravity
Variable containing the input gravity channel; designated by the variable $sGravity
In the expression, you can also use the variables:
Conversion factor used to convert the units of elevation to metres
Elevation channel
Latitude channel
For example, the syntax of the standard free air correction equation can be written as:
2. Bouguer Anomaly
Bouguer anomaly corrects the free air anomaly for the mass of rock that exists between the station elevation and the spheroid. It includes a correction for water depth and ice thickness if the "Water" and "Ice" channels are non-zero:
Bouguer Anomaly Correction Formula
For ground survey (including on lake surface) or shipborne (marine) survey:
For airborne survey:
Where:
Gb
Bouguer anomaly in milligals
Gf
Free air anomaly
D
Bouguer density of the earth in g/cm³
Dw
Bouguer density of water g/cm³
Di
Bouguer density of ice in g/cm³
Hs
Hw
Water depth in metres (including ice)
Hi
Ice thickness in metres
Gc
Curvature (Bullard B) correction
Hg
Ground (DEM) elevation at survey station location in metres
Water Channel
The "Water" channel contains the water depth at the gravity survey station location. These depths should be positive or zero.
Curvature (Bullard B) Correction Gc
The purpose of the curvature correction as a step in producing the Bouguer anomaly is to convert the geometry for the Bouguer correction from an infinite slab to a spherical cap whose thickness is the elevation of the station and whose radius (arc length) from the station is 166.735 km. Curvature correction depends on the station elevation (e.g.,1.1 mGal at 1000 m, 1.5 mGal at 2000 m, 1.2 mGal at 3000 m, 0.2 mGal at 4000 m, -1.5 mGal at 5000 m and –3.9 mGal at 6000 m), and latitude (ranging in dozens µGal). LaFehr’s formula [6], is used here for the curvature correction.
Figure 1: Schematic illustration (not to scale) of the spherical cap in Bullard B correction. The spherical cap surface radius of 166.7 Km, which is the outer radius or the Hayford-Boweie Zone O, is based on minimizing the difference between the effect of the cap and that of an infinite horizontal slab [LaFehr, 1991].
LaFehr expands the Bullard B correction calculation as per below:
Where:
BB: Bullard B correctionγ: Gravitational constantρ: Densityh: Elevation (from sea level)R: Earth radius to the station:
Where:
Ro: Earth’s sea level radius at the survey location
μ: Dimensionless coefficient:
λ: Dimensionless coefficient:
Where:
α = The half angle subtended at the earth’s center by the section of the earth’s surface at sea level for which the outer distance from the station is normally taken to be 166.7 km.
For context, below is what each of the Bullard corrections refers to:
- Bullard A: approximates the local topography (or bathymetry) by a slab of infinite lateral extent, constant density, and thickness equal to the elevation of the point with respect to the mean sea level.
- Bullard B: curvature correction, which replaces the Bouguer slab by a spherical cap of the same thickness to a distance of 166.735 km.
- Bullard C: terrain correction, which consists of the effect of the surrounding topography above and below the elevation of the calculation point [Nowell, 1999].
3. Complete Bouguer Anomaly
The Complete Bouguer anomaly corrects the Bouguer anomaly for irregularities of the earth due to terrain in the vicinity of the observation point. The terrain correction GXs can be used to calculate the terrain correction.
The complete Bouguer anomaly equation is:
Where:
The term is calculated in the Gravity Corrections GX
The term is calculated in the Latitude Correction GX
The terrain effect at density ρo
The term is calculated by this GX for all incremental ρo values
The gravitational constant (G) is a physical constant that is difficult to measure with high accuracy and which has varied broadly over time. G is re-evaluated every four years approximately. The table below lists published figures along with the uncertainty and source.
Published G Values:
Year
G (10−11·m3⋅kg−1⋅s−2)
Standard Uncertainty
Reference
1969 6.6732(31) 460 ppm Taylor, B. N.; Parker, W. H.; Langenberg, D. N. (1 July 1969). "Determination of e/h, Using Macroscopic Quantum Phase Coherence in Superconductors: Implications for Quantum Electrodynamics and the Fundamental Physical Constants". Reviews of Modern Physics. American Physical Society (APS). 41 (3): 375–496.
1973 6.6720(49) 730 ppm Cohen, E. Richard; Taylor, B. N. (1973). "The 1973 Least‐Squares Adjustment of the Fundamental Constants". Journal of Physical and Chemical Reference Data. AIP Publishing. 2 (4): 663–734. 1986 6.67449(81) 120 ppm Cohen, E. Richard; Taylor, Barry N. (1 October 1987). "The 1986 adjustment of the fundamental physical constants". Reviews of Modern Physics. American Physical Society (APS). 59 (4): 1121–1148. 1998 6.673(10) 1500 ppm Mohr, Peter J.; Taylor, Barry N. (2012). "CODATA recommended values of the fundamental physical constants: 1998". Reviews of Modern Physics. 72 (2): 351–495. 2002 6.6742(10) 150 ppm Mohr, Peter J.; Taylor, Barry N. (2012). "CODATA recommended values of the fundamental physical constants: 2002". Reviews of Modern Physics. 77 (1): 1–107. 2006 6.67428(67) 100 ppm Mohr, Peter J.; Taylor, Barry N.; Newell, David B. (2012). "CODATA recommended values of the fundamental physical constants: 2006". Journal of Physical and Chemical Reference Data. 37 (3): 1187–1284. 2010 6.67384(80) 120 ppm Mohr, Peter J.; Taylor, Barry N.; Newell, David B. (2012). "CODATA Recommended Values of the Fundamental Physical Constants: 2010". Journal of Physical and Chemical Reference Data. 41 (4): 1527–1605. 2014 6.67408(31) 46 ppm Mohr, Peter J.; Newell, David B.; Taylor, Barry N. (2016). "CODATA Recommended Values of the Fundamental Physical Constants: 2014". Journal of Physical and Chemical Reference Data. 45 (4): 1527–1605. 2018 6.7430(15) 22 ppm Eite Tiesinga, Peter J. Mohr, David B. Newell, and Barry N. Taylor (2019), "The 2018 CODATA Recommended Values of the Fundamental Physical Constants" (Web Version 8.0). Database developed by J. Baker, M. Douma, and S. Kotochigova. National Institute of Standards and Technology, Gaithersburg, MD 20899.
References
- [1] W. A. Heiskanen and H. Moritz, Physical Geodesy, (San Francisco: W. H. Freeman and Company, 1967).
- [2] R. J. Blakely, Potential Theory in Gravity and Magnetic Applications, (Cambridge: Cambridge University Press, 1995), p. 135.
- [3] R. J. Blakely, Potential Theory in Gravity and Magnetic Applications, (Cambridge: Cambridge University Press, 1995), p. 136.
- [4] R. E. Sheriff, Encyclopedic Dictionary of Exploration Geophysics, 2nd ed., (Society of Exploration Geophysicists, 1984), p. 141.
- [5] R. E. Sheriff, Encyclopedic Dictionary of Applied Geophysics, 4th ed., (Society of Exploration Geophysicists, 1991).
- [6] T. R. LaFehr, "An exact solution for the gravity curvature (Bullard B) correction", Geophysics, vol. 56, no. 8 (1991), pp. 1179-1184. DOI: https://doi.org/10.1190/1.1443138.
