Grid Data - Minimum Curvature
Gridding refers to the process of interpolating data onto an equally spaced “grid” of cells in a specified coordinate system. For an introduction to gridding and a summary of the different gridding methods click here.
Minimum Curvature Gridding
The minimum curvature gridding (RANGRID) method fits a minimum curvature surface, which is the smoothest possible surface that will fit the given data values. The method is suitable for data with a relatively large number of samples (it can work well with geochemical data from comprehensive regional and local surveys), and it is best used when data is randomly distributed, sampled along arbitrary lines, or if you want to include tie lines. For an overview of the method click here.
To perform minimum curvature gridding, you must supply a data channel, an output grid name, and optionally the grid cell size. In addition, you have a variety of options, including the ability to:
  • define the grid coverage (spatial limits of the area to be gridded, cells to extend beyond data).
  • grid the original data or its logarithmic representation (using cutoffs or a data range).
  • grid your data in a more compact and efficient way by gridding parallel to survey lines
  • specify desampling values (for low-pass filtering) and a blanking distance (for removing values beyond a certain distance).
  • define the tolerance to which the minimum curvature surface must match the data points and the percentage of points that must meet the tolerance for the iterations for the current processing step to stop.
  • specify the maximum number of iterations to allow.
  • adjust the tension to produce a true minimum curvature grid or to increase the tension to reduce overshooting problems in unconstrained, sparse areas.
The gridding process generates a grid file (*.grd) and a gridding report file (rangrid.log). The report file gives details about the input data and the parameters that were used for processing.
Use the Grid Data option from the Grid and Image > Gridding menu to grid data using the minimum curvature gridding algorithm.
ClosedExpand to view other menus where this option is available:
Radiometric Processing:
  • RPS > Plotting > Grid Data
UXO-Marine:
  • UXO-Marine Sonar Utilities > Grid Data
Minimum Curvature – Gridding Options
Data to grid
Select the database channel to grid. To specify an array element, append to the channel array name the element index in square brackets. For example, Chan[1] would indicate the second element of the array channel "Chan".
Script Parameter: RANGRID.CHAN
Output grid
Provide the name of the output grid file. This field is auto populated based on the active database and the selected channel to grid; however, you can override the default.
The default output grid format is selected automatically as the output file type. The type can be controlled using the browse dialog, which is accessible from the [...] button.
 Script Parameter: RANGRID.GRID
Gridding method
The current gridding method is displayed.
Script Parameter: GRIDDING_TOOL.METHOD [Minimum curvature: 0]
Cell size
Specify a cell size for the output grid. This field is auto populated with the calculated default grid cell size and rounded to the nearest ten or hundred:
See the Application Notes below for more details on adjusting the grid cell size.
Script Parameter: RANGRID.CS
Extents and Data
Spatial Extents
Grid extents
(X min, Y min,
X max, Y max)
Define the spatial limits of the area to be gridded. By default, these fields are set to the full extents of the current X & Y channels of the active database in order to include all the data in the database:
X min, Y min: the ground coordinates of the first grid point at the bottom left corner of the rectangular grid area (by default, the minimum limits of the input data file are used).
X max, Y max: the ground coordinates of the last grid point at the top right corner of the rectangular grid area (by default, the maximum limits of the input data file are used).
To grid a subset of the data, enter the limits of the bounding rectangle, or press the Draw Extents button to interactively define the boundary extents – the output grid coverage will extend to these limits.
Script Parameter: RANGRID.XY
[Draw Extents]
Press this button to interactively define the grid boundary extents: in the Grid Preview pane, use the mouse to click & drag to draw a box, then release the mouse cursor to accept the final size of the box. The X & Y values will be updated in the Grid extents fields, and the preview window will be refreshed to show the newly defined extents.
  • You can draw the box in any of the four possible ways (e.g., from bottom left to top right).
  • [Reset Extents]
    Press this button to reset the grid extents to the initial state of defaults for the active database.
    The Grid Preview pane (with Auto-refresh enabled) will be updated to reflect the change; however, the zoomed state (in/out) of the grid preview will not be affected.
    Blanking distance
    Specify the blanking distance: grid cells farther than this value from a valid point will be set to dummies in the output grid.
    Preferably, this parameter should be set to just greater than the maximum distance through which interpolation is desired. Normally, the blanking distance and the grid cell size should be set in conjunction. If no value is entered for the blanking distance, then the grid will cover the maximum limits of the data plus eight times the grid cell size.
    If a grid node is closer to at least one observed data point than the blanking distance, it will be calculated, and otherwise it will remain blank. This field is auto populated with the calculated default value as per following formula:
    Script Parameter: RANGRID.BKD
    Cells to extend beyond data
    This is the number of grid cells to extend beyond the outside limits of the data. The default is the integer value of blanking distance/grid cell size.
    If the X and Y range values aren’t explicitly defined, the grid size defaults to the actual data range plus this value (the specified number of cells).
    This parameter is typically used in conjunction with the blanking distance parameter. For best results, use the blanking distance to control coverage around the data, and use this parameter to set the default grid size – with this distance generally being smaller than the blanking distance to provide clipping around the grid.
  • Do not use this parameter in place of the blanking distance to fill interior regions of the grid. It yields inferior results because blanking distance measures the true radial distance between a given location and the nearest data point, whereas cells to extend beyond data is measured only in the X or Y. Since the blanking distance is a true  distance and this parameter is a count of grid cells, you must multiply the number of cells by the actual cell size to compare the two properly.
  • Script Parameter: RANGRID.EDGCLP
    Data Filtering
    Mask channel
    Select a channel from the drop-down list to act as a mask.
    Only database channels that have the class property set as "MASK" are listed. Additionally, string channels and channels with array size greater than 1 are omitted from the list.
    The data values in the selected Data to grid channel with corresponding dummy (*) values in the Mask channel will not be used in the gridding process.
    The X & Y values will be updated in the Grid extents fields to reflect the masked data, and the generated masked grid (with the correct extents) will be automatically rendered in the Grid Preview window (the Auto-refresh option must be selected).
    Script Parameter: RANGRID.MASK_CHANNEL
    Log option
    Choose whether to grid the original data or its logarithmic (base 10) form. Gridding in log space can help reduce distortion in highly skewed data, such as geochemical measurements.
    Available options:
    • linear: Grid the data as-is.
    • log, save as linear: Grid the base-10 log of the data (in logarithmic space). Any values below Log minimum are clipped at that threshold. The resulting grid is converted back to linear space before being saved to a grid file.
    • log-linear, save as linear:
      • Values above the positive Log minimum and below the negative Log minimum are gridded in logarithmic space.
      • Negative values are temporarily sign-flipped to compute logs, then flipped back.
      • Values outside the ± Log minimum range are converted back to linear space post-gridding and scaled to ensure boundary continuity.
      • Values within the ± Log minimum range remain intact and are gridded linearly.
      • Finally, the linear representation of the data (in both ranges) is saved to the grid file.
    • log, save as log: Same as log, save as linear, but grid values are kept in log space - the gridded data is saved to the grid file in its logarithmic representation.
    • log-linear, save as log: Same as log-linear, save as linear, but the grid values are not converted back from log space. The output grid remains in logarithmic space with large amplitude anomalies being somewhat moderated.
    See the Application Notes below for more details.
    Script Parameter: RANGRID.LOGOPT
      linear: 0
      log, save as linear: -1
      log-linear, save as linear: -2
      log, save as log: 1
      log-linear, save as log: 2
    Log minimum value
    When gridding in logarithmic space (see Log option above), this parameter sets the minimum threshold value. The default is 1.
    Script Parameter: RANGRID.LOGMIN
    Interpolation
    Minimum Curvature
    Low-pass desampling factor
    Specify the desampling factor as a multiple of the grid cell size. This effectively acts as a low-pass (smoothing) filter by averaging all points into the nearest cell defined by this factor.
    Leaving the default value (1) results in no pre-filtering other than de-aliasing by averaging data points within a cell.
  • If the resulting grid is too noisy around data points, increase the desampling factor. This option is generally used in conjunction with the Weighting power and Weighting slope parameters. See the Application Notes below for more details.
  • Script Parameter: RANGRID.DSF
    Starting coarse grid
    Select a value from the available options (16, 8, 4, 2, 1) to indicate the desired coarseness of the starting iteration level relative to the final grid cell size. The default is 16, which is suitable for most datasets. Reducing this value will increase the processing time and resolve the densely sampled areas more accurately.
  • Reducing this parameter is in juxtaposition with the log-linear and the Low-pass desampling factor options.
  • See the Application Notes below for further details.
    Script Parameter: RANGRID.ICGR
    Search radius
    The maximum search radius in number of cells to use for establishing the starting grid values for the coarse grid. For any grid node, if no data points are found within this radius, the mean value of the observed data is used as the starting value. The default is defined as:
    Script Parameter: RANGRID.SRD
    Weighting power
    The weighting power is used to generate the coarse starting grid. Values within a coarse cell are weighed by the inverse of their distance from the coarse grid nodes raised to this power.
    See the Application Notes below for more details on weighting power and the overall weighting formula.
    Script Parameter: RANGRID.IWT
    Weighting slope
    The weighting can further be moderated through the use of a slope parameter.
    The default value is 0.0, which means that the weighting formula is not applied, and only the data point nearest to a grid node is assigned to the node.
    If weighting slope is set to a value greater than zero, all data points within a block grid unit at each refinement level are weighted and used.
  • This is a distance weighting parameter that defines how the values of the gridded parameter found within one grid cell unit are combined in one weighted location and parameter value. The purpose is to reduce high-frequency aliasing caused by gridding at too fine an interval.
  • See the Application Notes below for more details on weighting slope and the overall weighting formula.
    Script Parameter: RANGRID.WTSLP
    Tolerance
    The maximum permissible deviation of the fitted minimum curvature value from the initial value assigned to the node.
    Specify the allowable absolute error per grid cell (in grid data units). The default is 0.1% of the observed data's maximum range.
  • Lowering the tolerance increases grid accuracy.
    Script Parameter: RANGRID.TOL
    % Pass tolerance
    The minimum percentage of points that must meet the specified tolerance. The default is 99%.
    For a higher-quality grid, consider increasing this threshold.
    Script Parameter: RANGRID.PASTOL
    Max iterations
    The maximum number of iterations at each level of grid refinement after which the gridding algorithm does not proceed further. The default is 100.
  • Increase this value if more iterations are required to produce a more accurate grid.
  • Basically, the gridding process stops if one of the following conditions is met:
    • The tolerance criteria are met (the Tolerance and % Pass tolerance parameters).
    • The maximum number of iterations is reached.
    Script Parameter: RANGRID.ITRMAX
    Internal tension
    The degree of internal tension (between 0 and 1). Default: 0, resulting in a true minimum curvature grid with no tension.Increasing tension can be used to prevent overshooting of valid data in sparse areas; however, curvature in the vicinity of real data will increase. In general, the sparser the areas in the data—with localized highs and lows— the higher the tension should be set.
    See the Application Notes below for more details on applying internal tension.
    Script Parameter: RANGRID.TENS
    [Restore Defaults]
    This button remains disabled until any of the fields default values are changed. Press the button to reset the gridding parameters to the initial state of defaults for the active database.
    When Restore Defaults is clicked:
    The following parameters are reset to their default values:
    • The cell size value
    • All the parameters on both the Extents and Data and Interpolation tabs
    • Only the parameters for the current gridding method are affected.
    The following parameters are not reset:
    • The data to grid selection
    • The output grid file name
    • The gridding method
    The Grid Preview (with Auto-refresh enabled) and Variogram panes will be updated to reflect any parameters changes; however, the zoomed state (in/out) of the grid preview will not be affected.
    [Run in background]
    Gridding can be a resource-intensive task. The duration can range from minutes to hours, depending on the size of the dataset. By choosing the Run in background option, you can execute the gridding process asynchronously, allowing you to continue using Oasis montaj for other tasks while the gridding is underway. Multiple instances of the gridding process can run concurrently in the background, whether they are for the same database or different ones.
    When you press the OK button with the Run in background option checked:
    An Oasis montaj command-line window (OMS) will open and run in the background on the taskbar until the gridding task is complete. Oasis montaj becomes available immediately after the OMS console window is launched. Do not close the console window before the process finishes — this will cancel the gridding, and no output grid file(s) will be produced. When the gridding process is complete, the console window will close automatically.
    In the current Oasis montaj project, in the Project Explorer:
    • You can monitor the progress of your gridding while working on other tasks.
      The progress of the gridding is monitored, and the status (e.g., processing, completed, failed, cancelled) is visually indicated in the Jobs tab. A new node is appended to the tab, and entries for each of the output files are created under this node in the tree.
    • As the gridding process for the selected database channel completes, the output grid is automatically added to the Grids node in the Data tab.
      You can double-click on the job node in the Jobs tab to initiate a re-run of the gridding using the previously set parameters. You also have the option to adjust these parameters before starting the process again.
    Closing the project (or the Oasis montaj instance) while background gridding is in progress will display a confirmation prompt. If you choose to close the project while the oms.exe is running in the background, the process will continue to execute to completion.
    The selection state of the Run in background option is retained on subsequent runs of the gridding tool in the same project.
    A unique, time-stamped log file is created and added to the project folder when running background minimum curvature gridding.
    Once a gridding task is executed, the gridding options are retained when switching between different databases. The Grid Data tool will recall the previous gridding parameters associated with the current database, regardless of whether gridding tasks have been performed on different databases since.
    The minimum curvature gridding creates a control file in your project folder. This file ( _rangrid.con) is then used by the gridding process. You can also build a RANGRID control file through a text editor and take advantage of further specialized settings not available through the Grid Data. To learn more, go to topic Minimum Curvature Gridding from a Control File.
    Adjusting the Cell Size
    Grid cell size should not be much less than half the nominal data point interval found in the areas of interest. A smaller cell size will more accurately fit the data points, but if the data contain errors this may not be desirable; it also means longer processing time and a larger output data size. A small cell size may also require a reduction in the iteration tolerance and an increase in the number of iterations to achieve an acceptable result. If the cell size chosen is smaller than the average data point density, then there will be many gaps in the output grid.
    If the data is to be contoured (we recommend 2 mm or 1/10 inch at plot scale for contouring), specify a smaller cell size and a larger desampling factor or regrid the grid using bi-directional gridding.
    With a larger cell size, the gridding algorithm averages more data points per grid node, thus the data appears smoother. However, increasing the cell size further is likely to introduce adverse results. It may dilute grid patterns that correspond to real geological features, thus obscuring real features. While dealing with large datasets, be aware of the trade-off between the processing accuracy and processing time, as well as the data storage requirements.
    The choice of the grid cell should also be reflective of the intent of the gridding process. If the near-surface information such as in UXO investigation is of primary concern, the grid cell should be selected in the order of ~0.1 m. If the surface geological structure is of primary concern, such as in gold exploration, a larger grid cell should be selected – in the order of ~10m. If the deep seated geology is being investigated, such as in the case of oil exploration, the cell size can be much larger, in the order of ~100 m. A simple rule of thumb is to select the cell size roughly equal to the shallowest depth of interest.
    Log Options
    If the data range is very wide and spans over several orders of magnitude, gridding in normal space may not honour the data distribution of interest, and the real patterns present in the data may get obscured in the process of gridding. If, however, the data is gridded in logarithmic space these very patterns will be revealed. Often it is more appropriate to grid geochemical data in logarithmic scale, as the element distribution changes in concentration by orders of magnitude over a short distance. Furthermore, depending on the data concentration and scatter, in order to maintain a consistent texture, it may be more appropriate to display the extremes of the data distribution in logarithmic space while the median range remains in linear space. This would be an appropriate approach with bimodal data.
    The log-linear options are not appropriate for geochemical data; they are intended for levelled geophysical data (e.g., sometimes the span of magnetic data is quite broad and in order to be able to observe the definition around the mean of the data distribution as well as at the extremes, this option is used). Prior to gridding the data for the two log-linear options, the data is altered as follows:
    if ( Z > Log_minimum))  Z = (log10( Z / Log_minimum) + 1.0) * Log_minimum);
    if ( 0 < Z ≤ Log_minimum))  Z is untouched
    if ( -Log_minimum ≤ Z ≤ 0))  Z = -Z
    if ( Z < -Log_minimum))  Z = -(log10( -Z / Log_minimum) + 1.0) * Log_minimum);
    This has the effect of treating large positive or negative values like logarithms, but gives a linear transform for values around zero.
    Log minimum value: when gridding in log space, this setting specifies the minimum cut-off in linear space. If one of the log, save as options has been selected, all values below this cut-off are replaced by Log_minimum. If one of the log-linear, save as options has been selected, this entry represents the two boundaries where the switch between linear and logarithmic gridding occurs.
    The illustration below intends to convey the variation between the various log options.
    Low-pass Desampling Factor
    The data sampling density used when calculating a grid is controlled by the grid cell size. Highly sampled areas would have the tendency to manifest a higher noise level compared to the surrounding lower sampled regions. In some instances, you might want to further smooth the regions with a high level of clustering without affecting the more sparse regions. Low-pass desampling is an appropriate approach for smoothing this data and it effectively acts as a low-pass (smoothing) filter by averaging all points into the nearest cell defined by this factor. For example, a factor of 3 would first average database points into a coarse grid with cells size 3 times the final cell size.
    The low-pass desampling factor parameter defines the size of the square within which the observed data is averaged.  The data is subdivided into adjacent bins of this size within which at most one averaged value is retained. This value should be specified in terms of number of grid cells as opposed to distance units.
    The parameter is generally used in conjunction with the Weighting power and Weighting slope parameters. The weighting power attributed to each observed data point is either the inverse distance to the grid node or the inverse distance squared. Furthermore, in order to counteract the aliasing problem, the weight slope factor can be used. Airborne data by nature has a high sampling rate along the traverse and low sampling rate across traverses. The weighting slope offers a means of moderating the distance weight factor, where the sharpness of the 1/dn (inverse distance or inverse distance squared) factor is moderated. For anisotropic data, such as airborne data, this factor provides a higher weight for lateral points, away from the traverse lines.
    Data Point Weighting Settings
    Two settings define how the gridded parameter values are weighted to produce the initial node values:
  • The two weighting settings, can be used to reduce the high-frequency aliasing caused by gridding at too coarse an interval. Grids produced with the weighting factors are significantly smoother than those grids where only the data point closest to the grid node is taken into account.
  • Normalized weight curves W = 1/(D p+S -1)
    Controlling Grid Accuracy
    The gridding algorithm combines the observed data points within each grid bin to produce a single initial value for each grid node. A system of differential equations that defines a minimum curvature surface is then numerically solved so that at best it crosses the initial grid node values and at worst comes within the specified tolerance of the grid nodes.
    The accuracy of the resulting grid is defined by how closely the solution surface matches the initial values and is controlled by the two parameters: Tolerance and % Pass tolerance.
    The tolerance is actually the minimum value of the largest change in the grid from one iteration to the next. When the change is below the minimum value, the iteration process stops. Therefore, it is not a direct measure of the accuracy of the fit to the data. It is usually best to make it very small so that the iteration process is controlled by the maximum number of iterations.
    The advantage of tightening the tolerance is to generate a grid that follows the observed data more accurately. However, this sometimes can produce a grid with higher frequency features. A few factors have to be considered when choosing the tolerance parameters, including the type of data, the data coverage, and the scale at which the interpretation is performed.
    Adjusting Gridding Algorithm Settings
    Maximum Iterations (RANGRID.ITRMAX)
    The purpose of this setting is to reduce the processing time; however, it is recommended to increase the value so that the tolerance criteria are met first. By default, this parameter is set to 100; you can easily increase it to as much as 500 without noticing much process time degradation. Higher values of this setting tend to produce more accurate grids. At each greater coarseness level, the value of the maximum iterations setting is reduced by a factor of 2. As it is doubled each time the cell size is halved in the RANGRID process, its default value for an initial coarsest grid (ICGR = 8) is 12. If ICGR = 16, ITRMAX will be only 6, which is too small and ITRMAX should be increased to at least 200 in that case.
    Starting Coarse Grid (RANGRID.ICGR)
    The starting coarse grid setting defines the desired coarseness of the starting fitting level. Since at each level the grid cell size is halved, this setting is defined as a 2n multiple of the final grid cell size. By starting with a coarser grid, the algorithm can produce a reasonable result in under-sampled areas. As the coarseness decreases, the algorithm becomes more sensitive to high-frequency features in the data.
    The initial coarse grid ratio should give an initial grid size that is not less than about 1/4 of the maximum data spacing or gap. For gridding a 200m spaced gravity survey with 10 km spaced regional data, ICGR should be set to 16. For typical aeromagnetic data, a value of 1 would be adequate. However, this might well be much slower than using the default value since every grid point would need to be assigned an initial value by the weighted means method, which is very slow for a large number of data points, instead of one in 64.
    Search Radius (RANGRID.SRD)
    This parameter is used while processing the initial coarse grid. Initial values are assigned to the coarse grid based on the weighted mean of data within the search radius of each grid point. If the search radius is too small, the starting grid can be a poor approximation of the desired grid resulting in excessive processing time. If the search radius is too large, too much time might be consumed establishing the original coarse grid.
    When gridding densely sampled data, you may want to decrease the value to save processing time When gridding spare datasets, you may want to increase the value to avoid situations where no data points are found within the defined radius from a grid node.
    It is critical that you choose the search radius large enough to give at least one data point within the search radius of every one of the coarse grid nodes. Otherwise, the initial value assigned to it (global average) may be too far from the solution for it to iterate to its correct value. The default is usually large enough – except when there are very large gaps in the data relative to the cell size. This exception can occur when the gridding detailed surveys together with regional data.
    Overcoming Poorly Sampled Data
    Although a minimum curvature surface may be mathematically ideal, it is not well suited to under-sampled data. Data is said to be under-sampled when the sample density is not sufficient to define all details of the feature(s) being sampled. In theory, sampling should be at half the size of the smallest feature present. Note that this is half the smallest feature present in the data, not half the smallest features of interest. This is an important distinction because many types of data often contain noise, that is much smaller spatially than the features of interest. This noise can be comparable or larger in amplitude than those features of interest. If this noise is under-sampled, error (known as aliasing) can be introduced into the data. The higher the amplitude of the noise, the more significant the error.
    In practice, the cost of data is roughly proportional to the number of samples. Because of this, many data sets, if not most data sets, are undersampled in order to reduce cost. These data still contain useful information, but must be handled by the gridding process in such a way that aliased noise is minimized. Minimum curvature gridding (RANGRID) has two features, which the user can control to minimize this type of error: the low-pass de-aliasing filter and the internal tension.
    Random Gridding Line Data
    Although the minimum curvature gridding (RANGRID) is designed for randomly located data, it may also be used to grid line based data. This is sometimes desirable in situations where line data does not possess a predominant geological trend or where the data from tie lines and baselines is to be included in the gridding.
    If line data is to be gridded using RANGRID, the blanking distance should be set to just greater than the maximum line separation. The resulting grid will extend beyond the edges of the data by this distance.
    If this is undesirable, you can grid the same data by using bi-directional gridding (BIGRID) to create a mask grid that stops at the edges of the data. The GRIDBOOL GX can then be used to mask off the dummy areas defined by the BIGRID grid. For more information on bi-directional gridding and grid masking refer to the Bi-directional Gridding and GRIDBOOL GX documentation.
    For further information on working with the minimum curvature gridding parameters, check the Oasis montaj Fundamentals course at lms.seequentlearning.com
