Analytic Signal
Use the Grid and Image > Filters > Analytic Signal menu option (GRIDASIG GX) to calculate the analytic signal of a grid.
The option is also available in the 2D Filtering extension under the 2D Filtering menu.
Analytic Signal dialog options
Input grid |
Select the input grid. Script Parameter: GRIDASIG.IN |
Output analytic signal grid |
Specify the output analytic signal grid. Script Parameter: GRIDASIG.OUT |
Z-derivative method |
Select the method for calculating the Z-derivative:
Script Parameter: GRIDASIG.METHOD [0 - FFT; 1 - Convolution] |
Retain derivative grids? |
If Yes, the intermediate derivative grids (_dx.grd, _dy.grd, and _dz.grd) are retained and not deleted on exit. |
The analytic signal is calculated as the square root of the sum of the squares of the derivatives in the x, y, and z directions:
The analytic signal is useful for locating the edges of magnetic source bodies, particularly in cases where remanence and/or low magnetic latitude complicates interpretation.
The default Z-derivative method is the FFT method. However, for very large grids (greater than 4000 × 4000), using the Convolution method can significantly reduce memory usage and processing time.
