Longitude,Latitude to X,Y
Use the Gravity > Locations > Longitude,Latitude -> X,Y menu option (GRLL2XY GX) to convert longitude/latitude coordinates to X,Y coordinates in either a projected or local coordinate system.
Longitude,Latitude -> X,Y dialog options
Conversion method
Choose the conversion method:
  • Select Projected coordinate system to use a map projection.
    The New Projected Coordinate System dialog opens.
  • Select Local coordinate system to use a reference location and orientation (origin and azimuth).
    The Create Local X,Y from Longitude, Latitude dialog opens (see below).
Script Parameter: GRLL2XY.METHOD
Create Local X,Y from Longitude, Latitude dialog options
Longitude of local (X,Y)
The longitude of the geographic reference location associated with the defined local (X,Y) origin.
Script Parameter: LL2XY.LOCLON
Latitude of local (X,Y)
The latitude of the geographic reference location associated with the defined local (X,Y) origin.
Script Parameter: LL2XY.LOCLAT
Local X
The local X coordinate of the reference geographic location.
Script Parameter: LL2XY.LOCX
Local Y
The local Y coordinate of the reference geographic location.
Script Parameter: LL2XY.LOCY
Local length units
The units of the local coordinate system, selected from POSC-compatible abbreviations (for example, "m" or "ft").
Script Parameter: LL2XY.UNITS
Local grid Y direction (deg azimuth)
The azimuth of the local Y-axis, measured clockwise from geographic North.
Script Parameter: LL2XY.AZM
This procedure is useful if you have data points with known longitude and latitude coordinates, and you want to work in a projected or local X,Y coordinate system.
  • Projected coordinate system: For the projected method, the X,Y coordinates are calculated using the selected projected coordinate system.
  • Local coordinate system: For the local method, the X,Y coordinates are calculated by projecting the longitude/latitude coordinates using a Transverse Mercator projection centered on the specified reference location (defined by the local X,Y coordinates), then rotating the result to the specified Y-axis azimuth.
A local coordinate system is an arbitrary Cartesian coordinate system defined and oriented for the purposes of a particular study.
