X,Y to Longitude,Latitude
Use the Gravity > Locations > X,Y -> Longitude,Latitude menu option (GRXY2LL GX) to convert X,Y coordinates from a projected or local coordinate system to longitude and latitude coordinates.
X,Y -> Longitude,Latitude dialog options
Conversion method |
Choose the conversion method:
Script Parameter: GRXY2LL.METHOD |
Create Longitude, Latitude from Local X,Y dialog options
Local X |
The local X coordinate of the reference geographic location. Script Parameter: LL2XY.LOCX |
Local Y |
The local Y coordinate of the reference geographic location. Script Parameter: LL2XY.LOCY |
Local length units |
The units of the local coordinate system, selected from POSC-compatible abbreviations (for example, “m” or “ft”). Script Parameter: LL2XY.UNITS |
Local grid Y direction (deg azimuth) |
The azimuth of the local Y-axis, measured clockwise from geographic North. Script Parameter: LL2XY.AZM |
Longitude of local (X,Y) |
The longitude of the geographic reference location associated with the defined local (X,Y) origin. Script Parameter: LL2XY.LOCLON |
Latitude of local (X,Y) |
The latitude of the geographic reference location associated with the defined local (X,Y) origin. Script Parameter: LL2XY.LOCLAT |
This procedure is useful if you have data points with known local X,Y coordinates defined using a reference location and orientation, and you want to convert them to longitude and latitude coordinates.
Projected coordinate system: For the projected method, the X,Y coordinates are converted to longitude and latitude using the selected projected coordinate system.
Local coordinate system: For the local method, the local X,Y coordinates are first rotated according to the specified Y-axis azimuth, then converted to longitude and latitude using the inverse Transverse Mercator projection centered on the reference location.
A local coordinate system is an arbitrary Cartesian coordinate system defined and oriented for the purposes of a particular study.
