XYZ to Voxel
Use the Voxel > Conversions > XYZ to Voxel menu option (geogxnet.dll(Geosoft.GX.VoxUtils.ImportXYZToVox;Run)*), to import an XYZ file to a Geosoft Voxel.
XYZ to Voxel dialog options
XYZ file
Browse to select the XYZ file to import.
Script Parameter: IMPORTXYZTOVOX.XYZ_FILE
Output voxel
Specify the name of the Geosoft Voxel file to generate (.geosoft_voxel)
Script Parameter: IMPORTXYZTOVOX.OUTPUT_FILE
Coordinate System
Coordinate System
The Coordinate System dialog allows you to specify the correct coordinate system information (Datum and Projection Method) for the incoming XYZ file.
Script Parameters:
  • IMPORTXYZTOVOX.IPJ_NAME
  • IMPORTXYZTOVOX.IPJ_DATUM
  • IMPORTXYZTOVOX.IPJ_METHOD
  • IMPORTXYZTOVOX.IPJ_UNITS
  • IMPORTXYZTOVOX.IPJ_LOCALDATUM
The import does not do gridding. The data must already be in a rectangular grid form.
The import does support non-uniform cell sizes as long as all the cell sizes can be determined. See GDB to Voxel for information on how non-uniform voxels can be imported.
If a 3D Viewer is open during the import, then the output voxel will be displayed in that 3D view. Otherwise, the output voxel will be displayed into a new Voxel Viewer window.
If the output voxel does not display, open the Advanced Settings dialog (Project > Settings > Advanced) and under the Voxel Settings section, check if the Display Created Voxels option is set to "True".
